Question about BenQ FP567s 15" LCD Monitor
Monitor picture is sideways
How do I fix it?
  • 51 Answers
Re: monitor picture is sideways - BenQ FP567s 15" LCD Monitor Computer Monitors
Through your front panel of the monitor...
Posted on Jan 01, 2008
0 characters
3 Points
My monitor has flipped the display so the picture is sideways. how do i correct this
there should be a menu or setup button on the monitor, what you're looking for is a setting called display orientation, the two options for which are landscape and portrait. you want landscape.
Jun 26, 2011 | Hyundai W220D 22 inch LCD Monitor
The screen is turned sideways
It sounds like you accidentally press the key combination to rotate the screen. This is a feature on some video cards to allow portrait display with the right monitor. Your monitor does not rotate so the picture is sideways. To correct this problem simply click CTRL + ALT + Up Arrow and your screen should return to the correct orientation.
I hope this helps, if so please rate our solution.
Dec 22, 2010 | Dell E173FP 17" LCD Monitor
Your screen is set to sideways. These the common features for all video cards. You can set it back to default, just go to video control panel of your video card and find Display Rotation.
Nov 03, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Picture is turned
all you have to do is hold ctrl + alt and press the up arrow key and your problem will be fixed
Oct 02, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Everything is displayed sideways on my monitor. how can I fix that ?
I suppose you have Nvidia Card Installed if yes then Right Click Your Desktop and select Nvidia select Standard Settings and go to Display + Rotate Display and set No Rotation . Thats it!
May 10, 2009 | Dell E173FP 17" LCD Monitor
All pictures appear wider than they really are
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
Dec 03, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
View sonic monitor
Press Ctrl+Alt+up Arrow together.
Nov 01, 2007 | ViewSonic E70f 17" CRT Monitor
Picture is Sideways
Do a system restore. That worked for me.
May 22, 2007 | BenQ FP567s 15" LCD Monitor
BenQ FP567s 15" LCD Monitor Logo
98 people viewed this question
Top BenQ Computer Monitors Experts
Matthew Spark
Matthew Spark
Are you a BenQ Computer Monitor Expert? Answer questions, earn points and help others
