Question about SiPix SC-3300 Digital Camera
Mem card when i place my mem card in the cover will not close,
  • 1,027 Answers
Check the pin alignment for compact flash as the sipix 3300 only takes compact flash standard not CF2 and only 128mb max capacity cards. From the pin grid to the end of standard card is 1 3/8"
Posted on Feb 09, 2008
How do you put a microsdhc card in a noble tablet
You can add a properly formatted microSD card inside the rear of the device:
  • Power off your Nook, unplug from power, and disconnect it from any USB connection.
  • Place it face down on a kitchen towel (so it won't get scratched).
  • Find the tab near the center of the bottom of the back cover.
  • Lift the tab (gently)and open the back. Note that the cover is snapped-in at the bottom, the middle and the top. Unsnap the cover carefully.
  • Identify and open the microSD slot cover with a fingernail, not a screwdriver!
  • Drop the microSD card into place, while lining up the contacts.
  • Close and then lock the card holder.
  • Replace the back cover onto the Nook
  • Snap the sides into place,and close the tab.
  • Power up and enjoy
NOTE: the card needs to be formatted using FAT32 or FAT16 not NTFS!
Jan 04, 2015 | Tablets & eReaders
My phone was in my pocket when i jumped into the pool .. how do i dry it out ??
remove the battery and keep in dry place where sun shine is there for 1 hr remember to cover the lcd part with a blck cloth and rest all to be exposed to sun remove sim and mem card and battery
Jun 27, 2011 | Audio Players & Recorders
No displa
try to power your board first see if the HDD light blicks .... if not turn off your computer remove your mem card clean the brass connector for your mem card using a pencil eraser and clean the mem card seats on the board using a brush then re-seat your mem card ... if stil not working replace your mem card with known good mem card if its ok replace your mem card
if theHDD light blink and no display check your video card clean your video card from dust build ups and also clean the brass connector using pencil eraser clean also the video card seat using a brush if your video card doesn't work have it replace
if your using a built in video card use an add on video card
Feb 24, 2011 | ASUS P5PE-VM Motherboard
Card Error
1. Change batteries, MEM Error/Card Error can also be that the card is FULL in which caseyou upload those precious shots to the PC, then delete them from the card ;-)
2. Look at the card. Does it have a small slideswitch on one side? If so, that is the WRITE safety, and should be marked (ON/OFF, WRITE/SAFE, LOCKED/UNLOCKED etc...) If there is one, and it is not marked, simply slide it to the opposite position. If I recall, most are slide DOWN toward the gold contacts to allow writing and you may have inadvertently caught that slideswitch on the edge of the MEM card slot or the camera body when pushing in in and moved it UP to LOCKED.
3. Get an eraser and CLEAN those gold contacts
4. But another card and see if it works(?) if not, you may have bad or bent contacts INSIDE the camera ((in the MEM slot) which will require a steady hand to fix.
Let me know... I may be close enought to help
Jan 15, 2009 | Polaroid I533P Digital Camera
Finepix z20fd memory card won't load in slot
Have you ever dropped your camera??
If you have , this is why.
No need to buy a new camera just yet.
Try celotaping it in.
My mom had to do this , after it worked fine!
Dec 26, 2008 | Fuji Finepix Z20fd Digital Camera
Hi, thanks for responding
Please remove your battery and polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
Next please remove your memory card and format in your pc using card reader and then use it on your cam.If you have another mem card then use it in your cam and see if you face the same problem.
Also try removing your mem card and battery from your camera and allow it to reset for 20min,then just insert the battery without the mem card and see if you face the same problem.
If you need any more help let me know..
Please don''t forget to rate or accept the solution no. 2 in the premium problem.
Jul 27, 2008 | Cameras
Memory Card Guitar Hero 3
Try this... if you have another Mem card then insert it in second slot and start Sony browser now copy your save game data form Mem card 1 to Mem card 2. Place the second mem card in first slot and start game now load your game. Best of luck.
May 08, 2008 | Sony PlayStation 2 (PS2) Console
Kodak easyshare Z760 battery and card holder fail
Mine does same thing, although when I close the little door, it still works fine.
Apr 06, 2008 | Kodak EasyShare Z760 Digital Camera
SiPix SC-3300 Digital Camera Logo
24 people viewed this question
Top SiPix Cameras Experts
Andrew Taylor
Andrew Taylor
Are you a SiPix Camera Expert? Answer questions, earn points and help others
