depending how many times the red ring flashes or how many re lights are on this could be the problem:
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Bewarned that opening your console voids any warranty on it, i would recommend contacting microsoft to see if it is still under warrenty as this could be a free fix by them
console wont turn on, like theres no power going to it. it worked fine and then without warning it...
(More)
console wont turn on, like theres no power going to it. it worked fine and then without warning it just stopped working. I tried other consoles in the same plug and they worked fine.
Update failed.Turned on xbox 360 and it is asking for update disc.down loaded fall update to...
(More)
Update failed.Turned on xbox 360 and it is asking for update disc.down loaded fall update to disc,put into dvd drive and press the A button.Update failed contact microsoft www.xbox/support.turned on and off same thing.I even tried a hard drive with new update.Whats next?
