Question about Fujitsu 24C1 Air Conditioner
Our AC won't come back on after i turned the power at the wall off and then on again. It was all working brilliantly till then and now i can't get a bit of life out of it. I can't even tell if any power is going to it. Remote works fine. House fuses are fine. Any suggestions? It's a split system.
  • floscar Jan 01, 2008
    air conditioner wont come on by remote. I have changed the batteries and remote display works fine. The manual/auto on off control button on actual air conditioner is still working but it does not respond to remote
  • vanhalla666
    vanhalla666 Feb 22, 2012
    Hi, I got similar problem as you. I cant seems to find another switch on the aircon itself. How did you solve yours ? Thanks
  • 236 Answers
To OzAnday
If the light indicator of your unit have light with power "on", then there is a problem with the unit. May the fuse of your pcb is open or the pcb itself has a problem. You have to call a qualified technician to check.
To floscar
Reset the rest button of your remote control, but if it wont work may the remote itself has a problem or the receiver board.
Posted on Jan 02, 2008
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
No power The light does not come on. The game does not turn. The fan does not blow.
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Dec 21, 2009 | Nintendo GameCube Console
The WII does not turn on, what do I check to fix it?
First:
Second:
Third:
Fourth:
Hope that helps!
Aug 12, 2009 | Nintendo Wii Console
My Wii console won't turn on.
First:
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
Third:
Fourth:
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Apr 09, 2008 | Nintendo Wii Console
Fujitsu 24C1 Air Conditioner Logo
539 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
