Question about Creative Labs Zen V MP3 Player
Creative Zen V Won't Charge, Won't be Recognized, Etc.
I took the Zen with me on a trip to Lake Tahoe and San Francisco and on the drive there it died. I forgot to bring the USB cable with me on the trip so I wasn't able to charge it until a week later (today when I got back home). I've connected it to the computer and nothing happened.
At random times it'll turn on but it'll shut back down immediately. Other times it'll flash but the computer says that the device is not recognized. I've tried reinstalling the program, pressing the reset button, connecting it to diffeerent USB ports. Nothing works.
  • 6 more comments
  • notsozen Jan 01, 2008
    My Zen V isn't recognized as connected by the Sync Manager. I had to reset it (using the needle), then powered it back up. Re-building Library displays, but then when I try to play any music, it freezes up again. When I attach it to my laptop, the laptop makes noise indicating that the computer knows I've attached something. When I look in Device Manager the Creative Zen V shows up with a yellow exclamation point, and the error is listed as "This device cannot start. (Code 10)".
    NOTE: My friend also has a Creative Zen. It's never been "rebooted", and when I connect it to my laptop, it's detected.
  • alpha22 Jan 02, 2008
    I have some of the same problem. Mine was working fine, but it suddenly won't charge when hooked to a USB port. It IS, however, recognized by thr computer.
  • aRaMeL Jan 05, 2008
    I got a Zen V Plus for xmas haven't been able to get it to work.
    At first, it looked like it was dead. After several attempts on several computers, and charging for 6 hours+, it appears to have power - the main buttons have a blue light, which fades away after some time.
    It still looks dead, but on closer inspection I can barely see on the screen - Re-building Library. But this keeps going and going... I have to be in a dark room to even make that out...
    It almost recognizes the device - when first connect by usb for a second it pops up New device found: Creative Zen... then a second later it shows that it has found MTP Device. When left on, it looks like the device appears and disappears every minute.
    Never been able to really connect it to any computer, never saw the screen work properly.
    I've tried the pin reset on the side, using XP SP2, meet all requirements, upgraded WMP to v11, all creative software installed as per instructions before connecting device, charged device...
  • angelannette May 06, 2008
    My Zen V is not detected on my computer and isn't in the device manager anymore. It will charge but you can't download anything to it. I'm running Windows Vista Home Premium. It woked fine until last Sunday, now nothing. Help
  • Anonymous Aug 31, 2008
  • s-ramanathan Dec 08, 2008
    Same problem. I havent used the player for last6-8 months the battery should have been drained complete. Not sure if draining complete on Lithium battery is the problem. Should I change the battery?
  • Jim Grossman Aug 16, 2013
    Check out the comment by dspanogle on this website. it is 2013 i know. but i still have mine and love it. it has worked up until now, but now all of a sudden wont. i dont know if the battery is just totally shot after 12 years(probably) or if my windows vista update on windows media player pehaps messed with the MPT settings on my vista which is causing it to no longer charge. Before i installed the CD on Vista and nothing worked, no software i mean, but for some reason it would at least charge, which was good. In the past the computer is all that has worked even a vista, but no power hub has, i once tried a powerhub that used 4 double AA batteries and it did nothing. I suspect for the reason in this comment i will add for a link having to do with 4 pins. I have not yet tried a wall charger, but after reading this comment i will try that. if all else fails, the battery is shot and it had a good 12yr run. Try this link though. VERY helpful.
Hey; I just had the same problem with my player; I uninstalled Windows media player 11 (brought it back to ten). Then I formatted my player, (You do this by unplugging it from the computer, then you turn off the player, and then you press the play button while also powering your player on, once you see the creative labs logo release the play button, a screen will appear, select format, then yes (it will delete all of your information on the player) then once you are done formatting select reboot. Once it's done rebooting connect it to your computer! It fixed the problem for me!
Posted on Jan 06, 2008
    Problem Solver:
  • 6 Answers
I had the same problem. Reinstalling Windows Media Player didn't help; nor did reinstalling the Creative drivers.
But this worked... in Device Manager I uninstalled everything under Universal Serial Bus controller, rebotted and let Windows reinstall the USB drivers. Had to reinstall my mouse software too, but the Zen is now back to normal.
Hope this helps someone.
Posted on Sep 14, 2008
Wow you are really good angelkassey!
But the thing is I can't make my window media player 10... it's a 9 instead :[
Posted on Aug 23, 2008
I think i good idea, would be if you have a x box, connect your zen to the usb and connect it into the front of the x box and give it ten seconds to settle and hey presto!
Posted on Aug 10, 2008
Creative is ****. I had a Zen before I got my Zen V and BOTH are fried. Buy an ipod. It's worth it.
Posted on Jul 26, 2008
Just wanted to say thanks sooo much to angelkassy. My player works fine now!
Posted on Jul 19, 2008
I left my Zen on the usb charger over night. In the morning it was DOA. I pressed the reset and everything is working fine.
Posted on Jun 11, 2008
I''ve had porblems on and off with my Zen MicroPhoto since the day I bought it and spent hours trying to rectify the problem and I've finally found the solution!!!
My player would not connect to my PC, both in XP or Vista, Media player seemed to make very little difference and I'm pretty certain the problems arose when I uinstalled the Creative software.
I had a 'code 10' connection problem in my device manager, from trying it on several computers I realised it wasent the operating system, the player had malfunctioned.
Here is the solution.. (option 3 worked for me)
1)I would like you to refer to the link below for the recovery tool
detection issues.
Troubleshooting MP3 Player Recovery Tool detection issues
2)I will need you to enter to the MP3 player recovery mode to do some
cleanup and reboot for 2 cycles. The cleanup option removes invalid
links and do simple housekeeping. The reboot option helps you to exit
from recovery mode safely and below is the link on how to do it.
Recovery Mode and Updating Firmware on a Creative MP3 Player
3)After doing the Clean-up and Reboot, I would advise you to update the
firmware using the MP3 Recovery Tool. Please kindly refer to the link
below. (if applicable)
Good Luck!! Creative Zen V Won't Charge, Won't be Recognized,  - progress.gif
Posted on Jan 23, 2009
Creative zen not reconised
What you might want to try is to connect the USB cable to the device and an open port on your PC and let it charge and see if after it has a full charge if you can power it on without having any other problem. Or if after it has a full charge if it is recognized by your PC as a connected device. If it has a full charge and recognized by your PC you should be able to use it without having any problem. Another solution is to download the updated firmware software, run the firmware update check your device and see if the display shows the Creative Labs logo if so you are in the clear and it should work without any other action needing to be taken on your behalf
Jan 31, 2010 | Creative Labs Zen Vision Digital Media...
Creative zen became frozen
Let the battery completely drain, and after a while charge it using the charger available else thru computer without turning it on.. let it charge for 50% and then try switching it on. Try this if not get back to me.
Jan 21, 2010 | Creative Technology Zen MX Black (8 GB)...
Zen problems
it may be in a low power state, try a different usb cable and hook it up to a desktop computer (laptop ports are sometimes not powerful enough to charge the battery when it is in a low-power state). I had this exact same problem and that fixed it!
Also check out and look at their support forumns
Jul 12, 2008 | Creative Labs Zen Digital Media Player
Creative zen malfunction with usb,Device not recognized
It looks like you need to restore the firmware on this players. There is a firmware utility. Sometimes though the creative player will not even be recognized by the firmware utility. Listen to the player and make sure the hard drive spins. If it does you can send it to a Creative Zen Repair service. They will take the hard drive out and write the firmware directly to the hard drive to get you up and running again.
Jun 15, 2008 | Creative Labs Zen Micro MP3 Player
Vision M not recognized
I'm having the exact same problem. My zen is 'charging' but isn't detected anywhere on my pc and I'd leave it charging for days but nothing happens. I've tried different usb ports, reinstalling the software several times but nothing. I recently reinstalled Windows and with my new pc my Zen cannot work on it for some reason?! I put previous files from my old pc onto my Zen hoping that I could transfer them onto my new Windows pc but I fear I've lost the data on my Zen completely. Arggh, any suggestions guys? Please..x
Feb 29, 2008 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen V MP3 Player Logo
2,620 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
