Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Cannot access
Please help! Thanks.
can not set wireless connection to my lap top
  • 27 Answers
Re: Cannot access
To HOMSIMS05: So you cannot connect the wireless device on your laptop to the router? If it is built in it may have a literal on/off switch on the outside and it might be set to off.
You may have also have disabled it somehow and enabling it and a reboot could fix it. You could also try installing new drivers from the adaptor website.
To Guest: can you access other web pages besides that one?
If yes then it could mean that your router has the same ip address as your modem. you would have to hook up your computer with the router without the router being connected to the modem and change the ip address of the router to anything besides set it to Then reconnect the router to the modem and see if you can access the webpage.
Posted on Jan 05, 2008
  • 112 Answers
Re: Cannot access
Check to see if the wireless device in the laptop is functional and not disabled by double clicking My Network Places and clicking Local Networks. Make sure that the wireless device you are trying to connect to has solid leds and not blinking, it would not hurt to restart the device. When it has solid leds click the wireless icon on the lower right side of the task bar, search for available networks, choose the one to connect to, and click connect. If everything is functioning correctly it will connect. BPCS
Posted on Dec 31, 2007
0 characters
6 Points
At the momenbt the router is fixed to the lap top by a cable, I want to establish a wi fi connection in my house for the lap top and iPad How do I do it please?
1. Log in to the DG834G firewall at its default LAN address of with its default user name of admin and default password of password, or using whatever LAN address and password you have set up. 2. Click the Wireless Settings link in the main menu of the DG834G firewall. 3. Choose a suitable descriptive name for the wireless network name (SSID). In the SSID box, enter a value of up to 32 alphanumeric characters. The default SSID is Wireless. Note: The SSID of any wireless access adapters must match the SSID you configure in the DG834G Wireless ADSL Firewall Router. If they do not match, you will not get a wireless connection to the DG834G. 4. Set the Region. Select the region in which the wireless interface will operate. 5. Set the Channel. The default channel is 11. This field determines which operating frequency will be used. It should not be necessary to change the wireless channel unless you notice interference problems with another nearby wireless router or access point. Select a channel that is not being used by any other wireless networks within several hundred feet of your firewall. For more information on the wireless channel frequencies please refer to "Wireless Channels" on page D-7. 6. For initial configuration and test, leave the Wireless Card Access List set to allow everyone access by making sure that "Turn Access Control On" is not selected in the Wireless Station Access List. In addition, leave the Encryption Strength set to "Disabled." 7. Click Apply to save your changes. 8. Configure and test your computers for wireless connectivity. Program the wireless adapter of your computers to have the same SSID and channel that you configured in the router. Check that they have a wireless link and are able to obtain an IP address by DHCP from the firewall.
Next, you will have to set your wireless key so that you can prevent everyone from accessing your router. To do this,
1. Log in at the default LAN address of, with the default user name of admin and default password of password, or using whatever LAN address and password you have set up. 2. Click Wireless Settings in the Setup section of the main menu of the DG834G. 3. Choose the WPA-PSK radio button. The WPA-PSK menu will open. 4. Enter the pre-shared key in the Passphrase field. 5. Click Apply to save your settings.
Jun 03, 2011 | NetGear DG834G Router
I put in the pass word a long time ago - have lost it - new lap top - how can I change the password ? so that I can use my new lap top on my wireless network
access the interface of the router and go on wireless there you will find the key that you have put on your router for wireless access..
Here is the step by step method ( connect a netwok cable to the router first ):
1. open your browser type in
2. Insert your username and password if it ask by default its username is admin and password:admin
3. Go on wireless
4. Click on Security
5. Copy the security key to your new laptop wireless and you should now be ready to access internet
If you need more help dont hesitate to ask me.. if it help you out please like the answer..thanks
Jun 01, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
Hi do you know how I can connect my lap top to the internet wireless with my linksys wireless router ? the lap top asks for an access code and I do not know what it is or how to find it do you know how to...
The access code or password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
Dec 27, 2010 | Linksys Wireless-G Broadband Router
I want to connect my lap top to a wireless Netgear
You need to do exactly that.
From your web browser type in put in you user name and password.
Your control panel will come up then you got to wireless settings and turn it on and set a Wep key, write that down then rebboot the router or save the settings.
go to your lappy now and open up your wireless card on the tak bar and search for your netgear click on it then enter that key, You should be good.
Thanks please do leave ratings for all the tech involed in your case, thanks
Jun 12, 2010 | NetGear RangeMax WPN824 Router
Need help...
The wireless router's wireless settings need to be configured eg. SSID, encryption etc. and then the wireless card in the laptop needs to be configured with the router's wireless setting so it can connect to the wireless router.
Please click in this link for details on how to secure your wireless network and follow my instruction :-
Jan 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference
Hope this helps!
Nov 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
New lap top
Open a web browser and type in the address bar.
Enter admin for the username and no password to get into setup.
Setup your account.
Apr 22, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wireless set up for ntl
hey thats easy man dont worry, if you have a existing broadband at home, just connect the broadband to your router, then connect the cable that comes up with the router to your laptop. then access the web configuration of the router, the ip address is usually written in the manual. then configure it with the settings that your Internet Service Provider gave you to connect. then configure the wireless settings and your done... if you still have problems, please feel free to contact me again..........
May 11, 2007 | 2wire (1000-400108-001) Router
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
262 people viewed this question
Top D-Link Routers Experts
 C. Dante
C. Dante
Are you a D-Link Router Expert? Answer questions, earn points and help others
