Question about M-Audio Delta 1010 Sound Card
S/PDIF not working
I bought my 1010 about a year ago from ebay and have not been able to get sound from the S/PDIF output on the card. I ran RCA cables from there to the inputs on my KRK ROKIT monitors and all I can hear is a VERY faint crackle of the audio I'm playing. I can use the 1 and 2 outputs on the breakout box just fine, but would prefer using the S/PDIF outs. Is it something with the M-Audio software that comes with this unit, something with the drivers, or possibly a hardware problem? Any light shed on the subject would be greatly appreciated!
Re: S/PDIF not working
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
Posted on Mar 01, 2008
0 characters
3 Points
Computer no sound tells me no drivers .i got drivers unz ipped them .told the computer where they are located computer says none found go online and get some.maya 1010 says install hard ware (it has been...
Use a driver finder tool to download drivers for this sound card. Also scan your PC with a system utility tool like Reginout to fix wndows registry and missing dll files. After fixing errors install sound drivers.
Apr 29, 2012 | AudioTrak MAYA 1010 Sound Card
Hii sir maya 1010 sound card pura raddy to use bolta hai or pura setoll ho gaya hai lekin jab humm icon me mause Tuch karte hai to wo Hat jata hai
Hii sir maya 1010 sound card pura raddy to use Problem with the AudioTrak MAYA 1010 Sound Card Hii sir maya 1010 sound card pura raddy to use bolta hai or pura setoll ho gaya hai lekin jab humm icon me mause Tuch karte hai to wo Hat jata hai Sir plz solution
Aug 31, 2011 | AudioTrak MAYA 1010 Sound Card
How can I connect headphone line from delta 1010LT sound card?
on output of sound cardsare coloured sockets,headphone/speaker socket is green
Jul 05, 2010 | M-Audio Delta 1010 PCI CARD Sound Editing...
Where can i get a free M-audio 1010 to download?
You can download the Delta 1010 drivers from the website
I hope this works for you :)
Apr 21, 2010 | M-Audio Delta 1010 Sound Card
No output
Make sure you have your speakers connected to the main output. Also, in the "Universal Control" "Mixer" window, make sure that at least one of the mixes are assigner to "Mo", which stands for main output.
Feb 03, 2010 | PreSonus FIRESTUDIO Sound Card
Would like help with hook up wiring
i can not find the sound driver of my notebook NT-R45 can you help me pls
Jun 03, 2009 | Sabrent SBT-USB51 External Sound System
Razer Barracuda sound problem (with temp. solution)
find new hardware wizard . microsoft uaa driver for high divinition audio
May 25, 2009 | Razer BARRACUDA AC-1GAMING SOUNDCARD 7.1...
M audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Oct 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
No sound from output 3/4
u can try this , please update the driver update for the same issue and update the driver for the sound device or please unistall and reinstalle the sound drivers on the system, or do systemrestore if it was working some days back .... check the
  1. Click Start , Run , and enter services.msc into the Open field. A services window opens.
  2. Scroll down the list of services and find Windows Audio.
  3. Right-click Windows Audio and select Properties .
  4. Select Automatic from the Startup type dropdown list, and click Start to start the audio service.
  5. Click OK and test for sound.
May 24, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
Loud buzz on every output with no audio
Look in the computer music mags and look fro M-Audio dealers. Ring them up and tell them the problem your having and see how much it will cost to fix. If it's humming then it's proably broke and needs repairing. Just make sure the sampel rate isn't set too low as well
Dec 26, 2006 | M-Audio Delta 1010 Sound Card
M-Audio Delta 1010 Sound Card Logo
205 people viewed this question
Top M-Audio Audio Cards Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a M-Audio Audio Card Expert? Answer questions, earn points and help others
