My hp 375 photosmart printer keeps saying"print cartridge cradle is stuck- clear jam then press ok". I can't find anything jammed in there. Sometimes, it will print a few pictures then the error message will come on again. What should I do?
There is probably a small piece(s) of debris floating around in there. Look very carefully for it with a flashlight. Try to remove it that way.
You can also buy "canned air" available at computer and office supply stores and use it to blow out the printer as thoroughly as you can.
Believe it or not, I have read where a small piece of skin has kept the carriage from moving properly.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
canned air did the trick. thanks so much!!
" - knauffk13
Photosmart 375 is not feeding paper properly. It either doesn't feed it all or begins and then jams....
(More)
Photosmart 375 is not feeding paper properly. It either doesn't feed it all or begins and then jams. Any fix for this?
The pinter has 2 cartridges - one regular black in and one for photos. The printer is only drawing...
(More)
The pinter has 2 cartridges - one regular black in and one for photos. The printer is only drawing from the photo black ink cartridge. I reloaded the regular black in cartridge, then shut of the printer, restarted it...its still did not make a difference.
My HP Photosmart A516 will not turn on. When I plug it in all I get is a bunch of colored lines in...
(More)
My HP Photosmart A516 will not turn on. When I plug it in all I get is a bunch of colored lines in the display screen and the there is no light next to the on button. None of the buttons responds. Can anyone help me?
