Cfm Klimaire KSWG009H113 Split System Air Conditioner
Problem for Cfm Klimaire KSWG009H113 Split System Air Conditioner
The part thats mounted inside on the wall sounds
By glaviano2003 on Oct 25, 2009
the part thats mounted inside on the wall sounds like theres crickets in it
Solution #1
posted on Oct 26, 2009
Not Rated)
psnyper11
Rank: Master
Rating: 72%, 4 votes
There's probably crickets in it, someone may have forgotten to seal the refrigerant/drain line hole from the exterior of the home.
Was this helpful?
Yes
No
Popular Solutions for Cfm Klimaire KSWG009H113 Split
Questions and Unsolved Problems for Cfm Klimaire KSWG009H113 Split
Do you recommend Cfm Klimaire KSWG009H113 Split System Air Conditioner?
Answer
Answer
we need the part number to order one Termostatic Expansion valve for Carrier package unit... (More)
Answer
I live in a manufactured home. When I turn on my heat on my amana it does not start.
Answer
I have an error code of CH 26 on my LG airconditioner 524AHN can you help me diagnose the problem.
Answer
Malfunction code indicator shows E3 machine will not start.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cfm Klimaire KSWG009H113 Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
