Beeping sound coming from samsung cpu; no image on screen.
    Brigadier General:
  • 6,966 Answers
Depending on how many beeps, the sequence and the interval, this is indicative of a fault in either the video card or the memory. In some models this can also refer to the bios/motherboard fault.
If you PC came with an add-on video card, try to remove, clean the little gold tips and reinsert back. If the video is built-in to the motherboard, then it is sharing the memory. You can do the same with the memories. Remove, clean, reinsert. A good way of cleaning would be with the use of a pencil eraser rubbing on the gold strips/pins.
Hope that this be of some help/idea. Pls post back specific model of your PC as well as the sequence of beeps.
Good luck and kind regards.
Posted on Jan 01, 2008
  • Louie  Role
    Louie Role Jan 02, 2008
    Hi again,
    Any development(s) with your Samsung PC?
    Cheers.
N148 plus notebook
you must take note to the beep of you laptop. when you turn the laptop op it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max.
Sep 17, 2013 | Samsung Computers & Internet
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Jun 25, 2012 | Computers & Internet
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
I am slowly rebuilding my computer. When I nearly got it finished, and turned it on, it came up with "Windows Was Not Found". Knowing what to do, I turned everything off, unplugged it properly, and...
Check for motherboard. use only 3 parts:
motherboard
PSU
CPU + COOLER
Connect your motherboard to PSU and see, if any LED light comes from motherboard. If LED is on, then try to turn motherboard on and see if cooler works.
Are case wires (power +, power -, hdd +, hdd -, reset+, reset -, power led+, power led - and speaker wire ) connected correctly?
Those wires look like this:
front-panel-headers-nsatmeh50lx5u1woeaeqllmn-4-0.jpgThis image is just reference.
If the power wire (sometimes called POWER SW) is not connected correctly, when you press the power button of case, PC just won't turn on.
If PC turns on and CPU fan spins, then try to add RAM, Graphics card and try again.
Next step is to hear BEEP sound. One short beep sound is normal, anything else is not normal and indicates the problem of the specific hardware according to the sound code. Sound code is BIOS dependent. In case ASUS A8V-E Deluxe, it is Award BIOS. Check below for Award BIOS beep codes
1 long, 2 shortIndicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
1 long, 3 shortVideo card not detected __ (reseat video card) or bad video card
Beeps repeating endlessly __ RAM problem.
Repeated high frequency beeps while PC is running __Overheating processor (CPU)
Repeated beeps alternating high & low frequency ___Issue with the processor (CPU), possibly damaged
Mar 17, 2017 | ASUS A8V-E Deluxe Motherboard
My screen does not come on when computer is turned on.I have a samsung syncmaster 2253lw as my main screen and have had both operating in the past at the same time.
Please check your plug if it is plug in properly or firmly. Locate the switch and turn it on again. If stil persist, try to inspect whether cpu is beeping while turning on. If its beeping something is wrong in your cpu or monitor depending upon the beeps.
Jan 27, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
When I start my CPU, I hear a sound that shows me that the equipment is on (that it's working), but the screen stays completely black, no light, no image on it. It happened all of a sudden. I switched it...
that iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Jun 15, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
6 beeps at start up
Sounds like a processor or cpu failure.
Beep Codes
Please vote if you found this information useful.
Thank You
Apr 18, 2008 | Dell Dimension 4300 PC Desktop
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Computers & Internet Logo
338 people viewed this question
David Payne
David Payne
