Plantronics - Bluetooth Headset Plus Base & Headset
Plantronics 220 blue tooth
shared by 5 users
posted by tracydm on Dec 31, 2007
can you please tell me where to get the set up instructions for my blue tooth?
Thank You,
Tracy
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Posted by raven66_2002 on Nov 02, 2008
i cant get my phone to recognize my plantronics 220. i have a motorola i335. what can i do?
Posted by Guest on Oct 19, 2008
I LOST THE INSTRUCTIONS FOR REGISTRATION AND NOW I FORGOT MY CODE
Posted by Guest on Aug 06, 2008
i need assistance in how to use the plantronics 220, bought online from verizon. have no idea how to set it up. have no directions.
Posted by vanessavegac on Jul 26, 2008
I am trying to make the bluetooth discoverale but my phone keeps telling me that the devide is powered off or out of range. When i hold the botton down it is either blue, or flashing blue and red and the phone still tells me the same answer. What can i do?
Best Solution
posted on Oct 10, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
very nice!thanks for the help!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on plantronics 220 blue tooth:
I don't want to Accept this solution
Best Solution
posted on Aug 07, 2008
FixYa! (100)
ManOwar1
Rank:Master Master
Rating: 97%, 76 votes
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
ManOwar
Thank You!
Best Solution
posted on Dec 31, 2007
FixYa! (100)
take123
Rank:Guru Guru
Rating: 89%, 127 votes
all you have to do is press the on button until a red stady ligth apear in this mode the bluetooth will send a signal to the phone that most be in bluetooth serching mode (varry frome one to another ) and the code is "0000"...good luck and rate me
Thank You!
Can you Help with these Headsets problems?
Plantronics - Bluetooth Headset Plus Base &...
I either have static, or when I get rid of the static, the...
I have received the Plantronics CS70 NC, however, there...
i bought new plantronics Bluetooth i. while setup it is...
I bought a new cell phone, but can't use the bluetooth for...
i have a motorola razor grey and i want to use this...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
