Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
My Phillips 60PP9202 60 lost it's blue hue
All of a sudden the color changed............. is it something we did?
  • 211 Answers
No sure what you mean the color changed. That could be caused by many reasons, and the most common is a bad convergence chip. Here is my regular response message to convergence problems:
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Lost color when scanning slides
Hi Silva,
i think the scanner,s ribbon cable is faulty.
Jan 10, 2014 | Epson Perfection V500 Flatbed Scanner
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Color is all wrong on tv all of a sudden. Is missing some color, skintones are not right and lips are dark and colorless. Tried changing video hue/saturation, but it doesn't do anything to correct the...
If you are connected with a component cable (Green/Blue/Red/White/Red) then check the connections on the back of the TV and on the back of the input device (ie cable box or DVD player). Sometimes if one of these get loose then they can throw your color off.
Good Luck and please rate this solution....
Jan 08, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Mitsubishi wd 52525 lost greens and blues. only colors on screen are red hues.
This the classic symptom for component input wires being crossed. Check color coding on tv input and signal sourse. Green,Blue and Red wires must correspond. If ok Is the color off on the tv menu also. If so and wires are ok replace light engine.
Nov 03, 2009 | Televison & Video
Color off seems amber
Double check the wb settings in camera, (and be sure to check WB Shift) I'd suggest adding a Blue shift to your images to compensate for the Amber until you find something thats a decent trade off, if you can't eliminate the amber shift.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Loss Of Blue Color
The loss of blue could be one of 3 things. First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables. Make sure the BLUE connection hasn't fallen out or is loose. The possibilities is the blue CRT (picture tube) itself or something in the blue CRT driving circuit.
Feb 25, 2007 | Toshiba 57H84 57" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
