Question about Rta International Patio Heater With Table
Patio heater with table
Lights but after waiting the five minutes and adjusting contol foe more heat nothinh happens and it usually shuts off like no gas is getting to burner
It would seem you are having a pressure problem. As the burner uses more fuel, it apparently is not keeping up with the fuel needs. This would indicate a loose fitting somewhere. Start at the bottom and where the regulator attaches to the propane tank. Then move to the other side of the regulator where it attaches to the hose/tube that goes up to the burner. Lastly, check where the hose or tube attach to the burner. Spray a little soapy water around the different fittings and watch for bubbles. If you find a leak, tighten things down. Leaks are often associated with changing tanks, moving the heater around, or fittings not being tight.If the heater is a used one, be sure all the normal maintainence is done. Bugs are attracted to the soot and get in all the small areas. This affects the burner and pilot light area. Spiders make webs in the pilot light tube and in the burner as do other bugs.
Posted on Jul 20, 2008
  • 288 Answers
With just the little info that you gave, I cant be sure, but as this is an outside heater, it may be possible that like a spider or wasp has crawled inside and did something that plugged the orifice or gas/air injector to the burners. A blow out with an air compressor may solve the problem, unless its way inside, then you may need to take it apart. Just recently I removed a wasp nest from a burner injector on a central package unit that had a larger diameter than a CD!!
Posted on Jan 03, 2008
My patio heater will light and run for about three to five minutes then shuts off, I can wait a few minutes and relight and it will do the same thing.
Hi, This can be caused by using butane during cold nights. Butane will start to freeze on cold nights but propane will work up to -6 . If already using propane then the most likely problem will be a worn thermocouple, these are consumable items. Found this site very useful, patio heaters problem solving.
Sep 19, 2011 | Napoleon Lifestyle Collection Bullet Model...
Out of the box the patio heater didn't work and I never returned it. The pilot would light then when you move the knob to the on postion the pilot would go out and it wouldn't fire up. I bought a new...
If it is beyond any adjustment period from Ace, I suggest you take this to a full service propane service center for repair. You shuld first check with your Ace hardware man.
May 10, 2010 | Ace Hardware Living Accents Patio Heater...
Flame out on a DCS Patio Heater
thermo-coupler (cheapest to fix) or valve
Jan 30, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
The pilot light will not turn off after the burner is on... I think it over heats, because it will just shut off after several minutes.... any suggestions? Thank you
The pilot light must remain on, even when the main burner is on, to keep the thermocouple hot. If the thermocouple cools off, the gas flow shuts off. It sounds like something is interrupting the gas flow. If this is an LP heater, try replacing the regulator.
Dec 11, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
My patio heater does not heat up properly
you need to replace the pressureregulater or have it ajust if it is ajustable thanks from gilles
Mar 14, 2009 | Rta International Patio Heater With Table
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Patio heater keeps shutting off
Returned it to Home Depot, paid $50 for upgrade to "better" unit.
Sep 28, 2008 | Coleman (5040B750) Patio Heater
Open Questions:
Rta International Patio Heater With Table Logo
119 people viewed this question
Top Rta International Heating & Cooling Experts
Steve Wood Plumbing...
Level 1 Expert
Paul Carew
Are you a Rta International Heating and Cooling Expert? Answer questions, earn points and help others
