There is a really loud whirring noise from behind the set when it comes on, it doesnt always come on the first time, and now the screen goes green randomly.
The Color Wheel in the Optical Engine is what is most likely causing the problem. It is a very expensive part and I would call Toshiba at 1800-631-3811 and see if they could help you with the cost and also referring a Service Repair Facility to you.
I hope this helps,
Skyassoc
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our...
(More)
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered 2 new bulbs, and the same thing happened. So now we think it is a problem with the actual TV. here is what happened: We turned on the TV, and we hear a loud buzzing sound for about 5-6 seconds. then the power light begins to flash, and then the TV restarts itself, and then this cycle happens again. We have tried unplugging the TV and trying different outlets, but nothing has worked. What is wrong with it, and what can I do to fix it?
Toshiba 52HM95 52 in. HDTV Television problem: A whirring noise has developed that is much louder...
(More)
Toshiba 52HM95 52 in. HDTV Television problem: A whirring noise has developed that is much louder than the normal fan noise. It continues for several minutes after the TV is turned off. (About the same timespan that the fan keeps running). Is this more likely a fan problem or a color wheel problem?
I have Toshiba 52HM95 that has a whirling sound when turned on and continues intermittently while...
(More)
I have Toshiba 52HM95 that has a whirling sound when turned on and continues intermittently while the set is. Then continues after the set is turned off. What is this and how do correct the problem.
