Question about Garmin zumo 550 GPS Receiver
Power where is the best place hook the zumo 550 wires to get power to the unit?
    Scholar:
  • 174 Answers
The best place is on the battery connectors, the battery works like a capacitor and whining sound from the dynamo/generator/voltage regulator is usually least close to the battery connectors. Dont forget to fuse it with the proper fuse, you won't be the first one to have a flaming bike if the wiring messes up!
Posted on Jun 10, 2008
How to fit zumo 550 to honda goldwing 1800a6
What I did was got an aftermarket holder for the GPS and plugged it
into a cigarette lighter holder, commonly available at auto parts stores, that I wired to the battery .
Aug 03, 2014 | Garmin zumo 550 Motorcycle GPS Unit
Zumo 550 randomly shuts down, sometimes won't power up again.
Commonly happened when playing MP3's using an early version of the firmware. Install the Garmin updater and install the latest firmware and patches.
My original unit did the same thing.
Jul 13, 2009 | Garmin zumo 550 GPS Receiver
Zumo 550 User Guide
You can find the different user guides for this unit (in different languages too) to download on this page: https://buy.garmin.com/shop/store/manual.jsp?product=010-00567-00&cID=135&pID=414
Jun 13, 2009 | Garmin zumo 550 GPS Receiver
Crackling noise then no audio at all while on motorcycle
In my opinion I suspect either a bad internal connection to the built in speaker or a faulty Bluetooth connection. Does the problem occur on both the helmet and speaker? If so, then the unit has likley had a circuit malfunction. If the helmet works fine but not the speaker, then I'd guess a broken or damaged speaker and/or speaker wire. Crackling noise is typical for broken wires or lose connections. Any decent TV repair place would be able to sort through it about 10 mintues before you have to return to for factory repair.
Sean
May 24, 2009 | Garmin zumo 550 GPS Receiver
How to hardwire to HD motorcycle
Black or ground to chasis, Red to battery if you want it to have power all the time.
To the fuse box to a switched line if you want it to turn off with the bike.
Be sure to have a fuse in line with the power wire to prevent damage to the GPS umit or a fire on the bike.
May 23, 2009 | Garmin zumo 550 GPS Receiver
Wiring To an 08 Ultra Classic
If you are mounting the unit to the bars or fairing, I would recommend using a power lead which is available in the fairing, rather than the AUX accessory switch.  The AUX switch sends power to a connector under the seat, in front of the battery.  You would need to run new wires up under the fuel tank, along the neck and into the fairing to connector your Zumo to the AUX.  Instead, there is a 12+ V switched ignition power lead which is not used on U.S. touring bikes and would be perfect for connecting your Zumo.  Pull the fairing off the bike (7 screws, TORX T-27) and look at the headlight harness, which is 3 wires, black, white, yellow.  Attached to this harness will be 2 wires, a black and an orange w/ white stripe.  The orange will have a red silicone cap over it to prevent it from shorting out in the fairing.  Cut the zip-ties which connect these 2 wires to the headlight harness and then hook it up to your Zumo, black is negative, Orange positive.
Apr 21, 2009 | GPS
Zumo 550
Make sure that the bike's electrical connection to the GPS unit is actualy not having power once you turn the key off in the bike. This GPS turns on with external power. It is inherent in to its design.
In the case were you cannot have the bike's power source to the GPS turn off with the key, see if you can wire a small in-line switch in series with the GPS unit so that you have an external power switch. This should be easy to do.
The models I have used from Garmin have their own power switch. You should be able to use its power switch to turn it off.
Jerry G.
Jul 19, 2008 | Garmin zumo 550 GPS Receiver
Zumo 550
my battery failed after less than a year of use. Garmin sent me a new battery and the unit is working fine now. The old battery would not provide ANY power to the unit.
Dec 13, 2007 | Garmin zumo 550 GPS Receiver
Unit won't draw power from the bike battery
Ay I just fixed my Zumo 550, that would constantly go into battery power when hook up to my Motorcycle, found the enemy I was fighting was lack of proper ground (-).
Aug 20, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
122 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
