Home | RCA | RS2656 Shelf System | RCA RS2656 Shelf System
Problem for RCA RS2656 Shelf System
By clancy123 on Dec 31, 2007
just the tweeters are working and 2 of the 4 fuses were blown we replaced them and they instantly blew again. The 2 fuses that were blown are the bottom 2 fuses.
Clarification Request
Posted by orevit on Oct 15, 2008
most electronic component stores dont sell just one fuse and just one capacito, they usually sell bulk packages. take your stereo to a repair man
Same Problem
Feb 05, 2009
-   were can i buy the fuses -   Guest
Feb 05, 2009
-   i need 2 fuses for model RS2657 the fuse is 7.5 amps 120v i cant find them any where -   Guest
Jun 12, 2008
-   mines a rca rs2657 model almost identical to the one in the picture... the only difference is the speakers. i blew my fuses recently and when i took my stereo apart and put new ones in... IT BLEW AGAIN!!! im currently looking for a burnt out diode which im guessing is the problem but i really dont know. if anyone else figures something out let me know!!!-   rcahelp
Jun 02, 2008
-   I have a RCA RS 2656 and it also seems I have lost all my base sound. I have not done any thing to fix it, but I see from some of the other questions there are some fuses, can someone tell me where to locate the fuses.
Thank You
Vince-   poodlehead
May 18, 2008
-   were can i get the fuses for the radio at-   Guest
Best Solution
posted on Jun 24, 2008
Helpful)
jonsingh12
Rank: Master
Rating: 87%, 17 votes
Had a problem with a customer's stereo system, i replaced the transformer and put in two new fuses and all worked good again. Another time it was a damaged capacitor allowing full charge to go through causing the fuse to blow immediately so i just replaced the capacitor and the fuse and all was good.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
were can i find these fuses at and were in spring
Popular Solutions for RCA RS2656 Shelf System
Questions and Unsolved Problems for RCA RS2656 Shelf System
Do you recommend RCA RS2656 Shelf System?
Answer
Answer
i had the volume up and the system cut out and when i got it turned on again now i cant get the sub... (More)
Answer
do u know anyone who sells the cd cover part for the rca rs2656?
Answer
Want to use use my direct tv remote to use with my RCA RS 2656 shelf system. What would the remote... (More)
Answer
I have a RCA RS2654 CD player and I need the electronic schematic
Answer
my RCA 5 disc changer will not open-there is not a disc in it
7 Other Users Have The Same Problem - Continued
Comment by RCAGUY, posted on Mar 04, 2008
Same problem. (2) 7A 125v fuses blew when vacuum cleaner was plugged into the same circuit. Replaced fuses - they immediately blew when the unit was turned on.
Comment by capehenry, posted on Jan 19, 2008
Yes we are haveing the two fuses blow too! Looking for a solution?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA RS2656 Shelf System:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
