Question about Microsoft Xbox Console
Flashing Red/Green. No error code on screen, but contact M$.
Light is flashing red/green and msg to contact m$, but no error code on screen.... Any idea's ?
  • 4 more comments
  • jkc1950 Dec 31, 2007
    by the way this is a 2001 xbox.....
  • Anonymous Jan 05, 2008
    I have the same problem. I was playing Brothers in Arms when the screen changed to purple,plack cubes.Then XBOX turned off. After that I tried to turn it on but just green/red light flashed. Next day I tried to turn it on again and XBOX turned on without problems.But when i turned it off again it didn't turn on never again (again there was green/red light) .
    I observed XBox better and now I know that if I leave it for few hours than first time when I try to turn it on it will be a yellow light (XBOX don't turn on) , but after that only green/red light (after 3 times tries to turn on).
  • javern nolan
    javern nolan Jan 06, 2008
    my xbox keeps sayign that it cant read the disc even the brand new ones
  • Anonymous Feb 17, 2008
    light is flashing orange
  • kevin dufour Mar 30, 2008
    i have the same thing going on with 2 of my xbox's wont load and flashes green and yellow i caint seem to get them working yet
  • John Matrix Apr 04, 2008
    I have a similar problem, but I think it might be related to the internal clock. I left my Xbox unplugged for awhile and then suddenly got the urge to play and hooked it all up, turned it on, set the date and time and played a couple of hours. I turned it off, and came back later and it wouldn't start up, the circle flashed red and I the screen displayed a error message to get into contact with support staff blah, blah, blah.
    I tried restarting with the on/off button but that didn't work so I had to unplug it and left it like it was.
    When I came back to it a day or so later, it ran perfectly on startup after I took the time to input the date and time but when I turned it off and tried to start it again, I got the same problem. I've been experimenting and I think it has something to do with the internal clock. Leaving it unplugged long enough for it to require a reset of the date and time seems to bypass the problem. But as that can take around 24 hours or more, I'm looking for a better solution.
Just to let everyone know, Its a heating problem.
Put your XBOXES in a cooler place also the power adapter is getting to hot,PUT A FAN TOWARDS IT, in other words LETS COOL THEM DOWN.
Posted on Apr 05, 2008
    Problem Solver:
  • 6 Answers
NO just like the wiz said check your red white and yellow cable it must not be in right try jaming it in!!!
Posted on Feb 21, 2008
  • 39 Answers
Check the back of the xbox make sure everything is put in.
Posted on Jan 06, 2008
  • Jeremiah Furlow Feb 06, 2008
    maybe you have to take it to be clean
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Cheers!
Dec 21, 2008 | Microsoft Xbox Console
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
How do I Fix flashing green and red light
What error number does it have on the screen? It should be a white number in one of the corners of the screen. If you find out what it is, then select add more details in this question and say what the error number is.
Dec 22, 2007 | Microsoft Xbox Console
Xbox
Flashing Red and Green has Numerous causes for eg: system failure. please mention the error code which is displayed on Top left corner of your TV screen as shown in following image.
Aug 26, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
127 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
