Question about Pioneer TS-A1057 Coaxial Car Speaker
Brand New Speakers Distorted and not right...
Just installed in a 96 cherokee in the door... Passenger only gettin highs (was doing the same prior to new speakers) drivers side just sounds all distorted... Sound like i need new wiring?
    Problem Solver:
  • 5 Answers
Are you still using the same head unit? You could try to run a short set of new wire to one of the speakers directly from the unit. Had you previously used these speakers in another vehicle...what I'm getting at is that you need to isolate the problem. If the speakers test fine in another vehicle, I would think there is something wrong with the existing head unit
Posted on Jan 04, 2008
pull the rubber boot back off the wiring harness in the crease of the drivers door and check for broken wires there. common problem due to the number of times these wires flex to allow the door to open and close
Sep 21, 2012 | 1996 Jeep Grand Cherokee
Wire diagram for installing a radio in a 2000 jeep grand cherokee limited?
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Oct 09, 2010 | Car Audio & Video
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
96 grand cherokee all electric right front and rear doors is dead
Sometimes the wiring breaks where the door swings open and close. You can remove the the boot and check the wires you will probally find some broken. Check good and feel the wires.
May 22, 2009 | 1996 Jeep Grand Cherokee
Passenger side dead.
Sometimes the harness at the front door will get a wire break in it. Try working the window switch on the passenger front door (ignition on of course) while slowly moving the door open and closed. If it starts to work, Jeep has repair kits still I believe where you can replace just the harness between the body a-pillar and door.
Mar 22, 2009 | 1997 Jeep Grand Cherokee
96 Jeep Grand Cherokee Laredo Speakers
front - 6.5" by 6.5" depth- 3"
in dash - 3.5" depth- 2"
back- 6.5" by 6.5" depth- 3"
Jan 25, 2009 | 1996 Jeep Grand Cherokee
Passenger front power window does not operate from either switch
Probably a bad window motor located on the inside of the door, you do have to be kind of contortionist to reach in and get but it's not too hard to replace part is under $50 if I remember correctly.
  • Remove interior door panel
  • Remove plastic sheet under cover
  • Unplug motor(now is good time to plug in your new motor to make sure it works prior to installation)
  • Unbolt I believe 3 bolts (3 bolts on 97 yours may be more or less) from window motor the bolts are located on the inside of the door
  • Remove motor
  • When installing new motor be sure the gears engage one another
  • Reinstall motor mounting bolts
  • Plug motor back in
  • Reinstall door panel
Nov 20, 2008 | 1994 Jeep Grand Cherokee
Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Jul 11, 2008 | JVC KD-G110 CD Player
Pioneer TS-A1057 Coaxial Car Speaker Logo
97 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
