Question about Acer Aspire 5100 Notebook
Acer Vista Lap Top Won't Recognize USB Flash Drives
I have the Aspire 5100 Lap Top with the Vista OS. It will not recognize ANY USB memmory devices. I took it back over the summer and received a new one....same problem. The memmory device will show up in device manager but I cannot access it...Please help!!!
  • kcpenner Jan 05, 2008
    My Acer Aspire 4315 recognized my flash drive the first time I put it in (I was transferring some files from the old laptop) but won't recognize it any more. I don't think the files are damaged because the old laptop (with good old XP) still recognizes it.
  • alexsabrina Jan 08, 2009
    the usb ports will not recognize the devices that i plug into it
    and i keep getting the same message from my pc unknown device keeps showing up
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
If Acer screwed up fixing your problem the first time (and it's evident that they did) they are obligated to fix it a second time, and if they cant, they are obligated to replace your laptop.
Posted on Jan 03, 2008
  • Richard Roberts Jan 03, 2008
    By the way, Acer unloaded a bunch of laptops cheap with Vista loaded, and sometimes only 512 MB memory--and some even with and M-chip, not dual core. If that is your case, you will have one headache after another, because to run properly, Vista requires at least 1 GB memory, and many people think 2 is necessary. DONT buy more memory from Acer if you need it--they'll rip you off. Their morality is less than desirable.
Why won't my Acer Laptop 5100 recognize any printer, data key, USB hubs when I put it in any USB port but will recognize a mouse, keyboard, and other devices?
Go to any search engine such as GOOGLE and typ in the model of your printer along with the manufactures name as well. Here is an example.... Lexmark 3150
The type in free driver after the name and model number
You will see a host of websites that will have a driver for your printer so it will work on your computer. Just download it and you'll be set to use it in minutes
Jun 25, 2010 | Acer Aspire 5100 Notebook
Acer aspire 5100 BL51 windows 7 wireless driver
You will have to navigate this site; enter 'notebook', 'Aspire', and scroll to 5100; after that, you will have to choose 32 bit or 64 bit. That being said, Acer does not support Windows 7 yet-you can try the Vista drivers; more often than not they will work. One note-I cannot tell just from the info you supplied whether you have the Atheros or Broadcom chip-You should be able to determine that in Device Manager.
Mar 10, 2010 | Acer Aspire 5100-5022 Notebook
USB ports will not recognize any devices.
Hi Brian
You have not mentioned the make of your laptop and what OS you are running on, however a common solution to this problem would be as follows:
1) Try doing a clean installation of the OS and check if it is detecting USB devices or not
2) Try finding a BIOS update for your laptop from manufacturer website and update the laptop BIOS
3) If the above steps do not work probably the USB controller integrated to motherboard would not be working, suggest sending it to the customer support of laptop manufacturer to get the motherboard replaced.
Nov 18, 2009 | Acer Aspire 5100 Notebook
Acer 5100
Is the keyboard on the laptop working? Also Does it recognize when you are plugging in the usb device? Go to your device manager and see if there are any exclamation points. Its possible a driver is corrupt or not installed.
Jul 11, 2009 | Acer Aspire 5100 Notebook
I have and Acer Aspire 3100 And im running a VISTA system, the usb ports have stopped recognizing everything, from web cams to ipods and flash drives. How do i fix this?
Go into the Control Panel, System, Device Manager.
Right-click the usb ports and choose uninstall.
Reboot the computer.
That should do it.
Jun 15, 2009 | Acer Aspire 3100-1405 Notebook
USB ports wont recognize anything I plug in
Are you using XP? If so:
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
3. Select HARDWARE
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 02, 2009 | Acer Aspire 5100 Notebook
Vista won't recognize usb flash drives
Did you format the flash drive?. Try it in another machine and just right click on format. I had a similar problem and that worked for me. If you have an xp machine available, use that one. Also you can create another account and establish the admin rights, then delete the current one if you don't want to have to click on which acct to use on startup, the password should be removable in safe mode, from the conrtol panel, under user accts.
Feb 27, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5610z card reader
goto to start menu
click on my computer--this will show all drives and devices
find your media reader drive
right click on that--goto properties
click and you'll see different tabs, so go thru each of them
and try to restore all defaults--
not sure what os you are running on so let me know if i was of any help to you.. thanks, d
Feb 27, 2008 | Acer Aspire 5100 Notebook
Usb ports do not recognize flash drives
regisrty key maby u could try repairing your windows back it all up redo it maby sum spyware or sumthing if not bad board not powering good engh to usb
Jan 22, 2008 | Acer Aspire 3100-1405 Notebook
Pen drive problem
Vista doesnt recognize all pen drives. only few like Sandisk, Transcend etc get recognized. Even brands like kingston don't get recognized. so to make them work install the driver for the pendrive. If you specify the brand of your pen drive ..i will try to help out with a driver .
Dec 11, 2007 | Transcend (589307) Media
Acer Aspire 5100 Notebook Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
