Question about DeLonghi D882UX Cool Touch Roto Deep Fryer
Delonghi D882-UX ROTOFRYER
Unit light comes on for temp., basket turns, but unit doesn't heat up. Can you recommend fix-it we can do? DOn't have the manual, but unit is relatively new.
  • Anonymous Apr 01, 2008
SOURCE: Delonghi DH100P problem
there is an air filter and an inline small water filter. which one needs to be changed?
Posted on Sep 06, 2008
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
  • 134 Answers
here you go
Please leave feedback
Posted on Feb 13, 2009
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
  • 276 Answers
SOURCE: Delonghi Magnifica After heating up, Unit kicks
Husband suggests that could be coming broken off the brewing unit as it should be activating, He suggests you should get in contact with your local De'Longhi Service Centre (should be info on how to contact in your User Manual, or google De'Longhi for your country).
Posted on May 19, 2010
My Sta-Rite poll heater doesn't work. The heater comes on when every time I restore power to the unit, the membrain buttons only work to change the temp. ont to shut off the unit, I use the service...
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
Sep 12, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
Hi On our portable DeLonghi air con, we have
Temp setting is very low. Raise it. And also service your unit frequently.
Dec 24, 2010 | DeLonghi PAC C100 Air Conditioner
De'Longhi Rotofryer FRP Easy Clean Fryer, 1kg instructions
Unfortunately the model you have does not have the drain tube. The FI8 is the model you are thinking about. The FRP has an arrow at the side of the rim to show where to tilt the fryer AFTER THE OIL HAS COOLED, FOR TWO HOURS AT LEAST!! Hope this helps you.
Mar 20, 2009 | DeLonghi Kitchen Appliances - Others
Delonghi DCU72 Light goes on and unit does nothing
If the light is going on...the thermostat is bad. Usually, the replacement can be gotten at any appliance parts website. You'll need a 180 degree unit. What you'll need to find inside is a unit about 5/8 inch in diameter 15mm. This has two connectors on it. Depending on the wiring, you'll likely need a low temp closed unit.
Feb 25, 2009 | Coffee Makers & Espresso Machines
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
DeLonghi D882UX Cool Touch Roto Deep Fryer Logo
60 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
