Question about Yamaha HTR-5730 Receiver
5.1 surround not working
Only the front 2 speakers will work. Even on Tuner setting, the sub and the surround are not working. The speakers and sub have been tested separately and are working just fine, just not as they should with the receiver. The only thing that I can think of that would have caused this is a power surge....any suggestions?
    Problem Solver:
  • 11 Answers
Re: 5.1 surround not working
Adjust your sound outputs with the remote and adjust the +/- settings on them and ten try another sound output adjust the stero effectsand try playing around with that and try cutting the speaker cable back about 2 inches and using a new peice of the cable to see if it's the cable causing the issue.
Posted on Apr 30, 2008
0 characters
3 Points
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
You have a very good of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2) order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio & Video Receivers
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio & Video Receivers
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
How to switch on Sub?
surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
Nov 16, 2009 | Sherwood R-945 Receiver
I have a yamaha htr-5240 receiver. Also have a 6 speaker polk-audio surround set.Center,2 rear,2 front,& the subwoofer. The sub is a psw-250 with no sub out or LFE.I can't figure out what i've done...
First, look at the sub, their should be a switch for "auto" "off" "on" switch it to "on" Then use the Left input on the sub not the right. Left is for mono. Now, if you still dont have any sub, disconnect the RCA at the receiver and touch the end of the RCA, if the sub is on, you will hear a loud humm. Now, go back into the receivers Menu and go into manual setup, find "Audio" and select "Auto". That should do it. If not, put the receiver on "Tuner" and set the sound to 7 channel stereo (I'm not sure if the HTR series has this) or "Adventure" I'm a Yamaha RXV series Dealer so the names may differ. (check in manual for audio surround settings) Anyway, this should let you know if you've got all your spkrs working. Then make sure your TV's external audio is set to "Fixed" (it may be called audio out) depends on TV type. Scroll thru TV's audio menu. If you still have problems post a comment and I will help some more. Hope this helps
Jun 21, 2009 | Audio & Video Receivers
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
Speakers not working
They will only have ambient sound (not same sounds as front speakers). Also for each input (video 1, video 2, dvd, tuner, etc...) you need to choose what surround mode you would like to use via the "Listen Mode" button. There is a little pictogram in the display which indicates which speakers are in use.
Sep 12, 2007 | Arcam AVR-200 Receiver
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Yamaha HTR-5730 Receiver Logo
260 people viewed this question
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
