Colors won't align
I have a 60 inch projection modle vs-4061 and the whole picture is destorted and the align colors are wavey and won't move properly. is there a way to reset this. sometimes it resets the colors on it's own but it is happening more frequenly now and i can't get it to reset.
  • 579 Answers
The convergence amps have failed. This is pretty common on rear progection TVs. The standard fix is to replace the 2 big heat sink mounted modules (they should be part number STK _ _ _ ) and also look for any small low ohm resistors in the surrounding circuitry that may be burned. Then you have to perform the convergence procedure (get the service manual). You can do it yourself, but probably going to want a local TV guy to do it.
Posted on Dec 31, 2007
Wavey line at bottom of tv
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments any where,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it reistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Philips 60PP9363 60" Rear Projection...
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
I can see all three colores
you need lens alignment there are three lenses that needs to be aligned to work seamlessly
Aug 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Convergence problem, wavey at bottom some color distortion
Common problem on rear projection TVs. Either replace the convergence correction board or repair it. Usually a job for a technician or at least someone familiar with electronics. The fix is to replace the STKs and probably a couple of resistors. Can provide more info if needed.
May 11, 2009 | Philips 60P8342 60" Rear Projection...
Phillips Magnavox 60 inch tv
not showing a picture are making a sound.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Oct 03, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi 60 in vs-60707
. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Open Questions:
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
