GE Spacemaker Washer and Dryer Electric Laundry Center - White
Problem for GE Spacemaker Washer and Dryer Electric Laundry Center -...
WHen draining it over flows the exist pipe.
By celyl on Oct 25, 2009
WHen draining it over flows the exist pipe. It seems like he pump is pumping to much water thru. The drain cannot clear the water fast enough and causes water to overflow onto the floor. I check the drain and it seems to be clear. Water flows thru normal...
Comments:
Oct 25, 2009
- I live in a highrise condo and the washer drain worked perfectly lastweek and 10 years prior. I wonder if the vent pipe is clogged and other residents are having the same problems.
Best Solution
posted on Oct 25, 2009
Helpful)
drallim
Rank: Guru  GE Washers & Dryers  Expert
Rating: 87%, 726 votes
The drain pipe in the house may not have a local vent pipe to relieve sewer air pressure or the pipe diameter needs to be increased. I have found that if the hose end is tied into the house drain instead of just sticking it into the pipe end, (sort of like the loose fire-hose nozzle that flips back and forth) that the drain will accept the flood of water. Try that before calling your friendly plumber.
Comments:
Oct 26, 2009
- Isn't there someone that is employed to look after problems in the building like this? Surely each resident is not responsible for maintaining the sewer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
freetek
Rank: Guru  Washers & Dryers  Expert
Rating: 85%, 1800 votes
The machine's pump doesn't produce a lot of pressure but it does produce more volume than a faucet. I suspect your drain needs cleaning.
Was this helpful?
Yes
No
Asker's Testimonial
" I checked the drain but I will need a proper snake. I live in a 40 story condo building, i wonder if this is common infrastructure? " - celyl
Popular Solutions for GE Spacemaker Washer and Dryer
Questions and Unsolved Problems for GE Spacemaker Washer and Dryer
Do you recommend GE Spacemaker Washer and Dryer Electric Laundry Center - White?
Answer
Answer
Dryer making screeching noise. Could the dryer drum be dragging? How to fix?
Answer
My spacemaker's screen is reading dr. I don't know what this means or how to fix it.
Answer
spacemaker washer agitates, then drains and keeps draining and will not spin
Answer
The washer fills with water, but will not switch to the next cycle.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
