Question about Kenwood SW-303 Speaker
Sw 300 powered sub woofer
What amp or receiver would i need to set up suround sound system
my sub has outlets for wire to conect and also red and white input.
  • 36 Answers
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Posted on Jan 01, 2008
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Hi friends i am using kenwood subwoofer sw-300 its not working from two days, i observer relay triping sound from inside the amp relay omron g5r 2232p-kw 48vdc has continue tripping while power on,
Short circuit protection energizes. Check for any external short circuit with connecting sires to sub woofer. If it found OK, the sub-woofer output amplifier section circuit inside the set is fault. Short circuited component/s. Check and replace them. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 03, 2015 | Kenwood Car Audio & Video
How can I connect a subwoofer to this device (denon pma-520)
Look around for a subwoofer which has speaker level inputs.
Something like this;
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
I just bousght a martin ash home thearer can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
How to hookup
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
May 16, 2009 | Kenwood Audio Players & Recorders
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Amp won't put out sound
Hello, if you leave me your email I can send you the user manual for this amp. Best regards, Arpi
Apr 10, 2007 | Sony XM-SD22X Car Audio Amplifier
Kenwood SW-303 Speaker Logo
416 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
