Question about Singer Featherweight 132Q Mechanical Sewing Machine
Bobbin is not winding correctly
My bobbin is supposed to be self winding on my Singer 9217. However the thread is no longer winding around the bobbin it is winding under it. How can I fix this?
  • smileyapples Dec 31, 2007
    Thank you and Happy New Year to all.
  • Anonymous Mar 31, 2014
    can not wind the thread
  • 3 Answers
Slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
  • Carol Jan 24, 2012
    bzjen. Your advice worked for me! My self winding bobbin would not even spin to wind and I thought it would need expensive repairs. After 2 weeks of searching for answers that didn't help, yours did the trick! I think the slide plate was not pushing the "button" on the bobbin hard enough. I used a tiny screwdriver while running and it immediately filled the bobbin! I will just do this every time, because it works for me without expensive repairs. Thank you soooooo much!
  • cindylouburk
    cindylouburk Dec 11, 2013
    carol you are a lifesaver. If you lived near me I would cook you a scrumptious dinner. Thank thank you. You have no idea how much your tip means to me. I am working on Christmas presents and cried half the night because the machine wouldn't work. You are fantastic.
Directions for filling bobbin in Singer Model 9217. Am I supposed to load the bobbin with the presser foot up or down?
The needle and feed dogs should not move while winding the bobbin (this is a safety function). If they do on your machine, then the mechanism that disables them during bobbin winding is malfunctioning.
Generally, is it not good to run the sewing machine without fabric between the presser foot and feed dogs. The feed dogs will eventually damage the underside of the presser foot and the presser foot will wear down the points on the feed dogs.
Dec 12, 2017 | Singer Sewing Machines
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
Bobbin refuses to be wound on self-winding bobbin machine. Bobbin does not turn. The thread is winding continously on the bottom of the bobbin basket. Need help.
Just off the top of my so-called head, it sounds like something in the bobbin area is not seated correctly. However, I would recommend that you do a search on FB and Yahoo interest groups (also on PSW software); it's members are MOST helpful, and will be glad to work with you to resolve this problem.
Jul 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Singer 2263 will not sew because bobbin thread winds back around the bobbin
have you tried changing the needle?
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin case & also wound correctly
May 14, 2012 | Singer 2263 Mechanical Sewing Machine
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Apr 15, 2009 | Singer 7436 - INGENUITY
Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Feb 01, 2009 | Brother CS-8060 Computerized Sewing...
Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Nov 12, 2008 | Sewing Machines
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Singer Concerto sewing machine model 9217
i was having the same problem. try putting in a new slide plate - the pressure from it holds the bobbin down, but it wears thin after a while. fixed mine.
Feb 12, 2008 | Sewing Machines
Singer Featherweight 132Q Mechanical Sewing Machine Logo
810 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
