Question about Refrigerators
Coolent leak Avanti model 489
There is a hole in the coolant system on the floor of the ice box tray. I need to seal the hole and recharge the system with coolant. Can it be done and is yes how?
    President:
  • 1,314 Answers
This requires skill in refrigeration depending on size of leak how old is the unit and how large the leak avanti is a great company if less than five years o0ld they will replace unit get in touch with if older than them
Posted on Dec 31, 2007
How do i put coolant in haier model # hwfosxc7 rb?
oh man
you ask the right guy
you need to vacume test a cooler first
then fill it
you cant just 'recharge' because the old coolant isnt there
because it leaked out
get real ffs widen your scope
usually the compessor is the issue
coolent leaks because of a leak in the cycle
Jun 04, 2015 | Haier Heating & Cooling
Whats wrong when the passenger side floorboard is wet under the carpet, and the moisture is coming from underneth?
Most likely cause is a leaking heater core. Have your cooling system pressure tested and look for leak.
Feb 24, 2015 | 2000 Pontiac Grand Am GT
Signs bad water pump
Water in the oil which would look like chocolate milk. Oil in the cooling system which would look like tar or black dots floating in the coolent. Or a visible leak of coolent on the floor or ground. After checking the hoses and related gaskets for leaks look at the weep hole on the water pump. If there is coolant around the hole then the pump seal is bad.
Aug 17, 2014 | Arctic Cat 2005 500 4x4 Automatic LE
Leaking under left side. water lines ok. too close to ground to see where water is. hardwood kitchen floor is buckled. ice maker is putting out too much ice and falling out onto shelf. what do i need to...
It sounds like the water tray for the defrost mode is full, you need to check if the tray has moved or maybe the door rubber are not sealing and this will cause extra ice built-up, and will cause the leak.
Jun 02, 2011 | Refrigerators
My matag model # mzd2766ge side by side has been leaking water on the floor. This happens only sometimes but by the time we notice its a big puddle on the floor under my cabinets. is something blocked up...
if it has ice/water in the unit,check the hoses going from the supply line at the inlet valve on the refrigerator rear section,if theres a hole in the tube,when the ice maker calls for water to fill the ice trays it will leak out this pin hole during the time the water supply valve is open and then shut off when the valve closes due to no pressure on the line then,thats probably the reason the puddles not always there
May 13, 2011 | Maytag MZD2766GES Side by Side...
Leaking coolent fromunder front of engine
There is a small weep hole in the bottom of the water pump. If the seal starts deteriorating it can cause coolant to leak from the hole. Change the water pump and all should be well.
If I helped, please rate my answer and leave a comment. Thanks.
Dec 02, 2010 | 1998 Isuzu Hombre
Kawasaki KX250F 2006 model coolent leak
There are two seals on the impeller pump. Replace the seals an the leak is stopped. Put in a new cover gasket as well.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx Click on the "ENGINE COVERS" tab.
A “very helpful” rating for this answer? Thanks!
Jun 20, 2009 | 2006 kawasaki KX 250 F
Fridge Compartment Ice
Freon can still be used but only by service professionals. The 134a coolant is not compatable with the old freon system without changing the seals.
Apr 30, 2009 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
