I was playing a video game on Windows 7 and accidentally hit what i think was the hibernate key. It went down like it was going into sleep mode and I frantically tried to get it out of what I thought was ''sleep mode''. It started up, but then it rebooted on its own with a different boot up than I'm used to. It was doing weird things like telling me there was no hard disk and when it finally booted up, it was ''resuming windows.'' I waited a few minutes and it didn't do anything so I rebooted it and this time it asked if I wanted to start it or resume windows, so I picked ''start windows.'' When it came up it told me there was no internet, and there were drives on it that were NOT there before, like a floppy drive. After a few reboots and restoring the Bios to the way we had it, there was still no luck, so I tried a format. That definitely did NOT work, and I have no idea what's wrong...my main problem is there's no internet and there are drives there that weren't there before/don't exist. What could have possibly caused this??? My friend said it might have been a RAM overload and caused the computer to try and reset itself, but i don't know. The motherboard type is Asus P5QL Pro, if that helps at all. Please, any help at all would be much appreciated.
SOURCE: Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
SOURCE: installing extra memory causes freezing + closing down of pc
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications
www.microsoft.com/Genuine"]
CPU
Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support
Chipset
NVIDIA nForce2 IGP
NVIDIA nForce2 MCP
Front Side Bus
400/333/266 MHz
Memory
-Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets
Expansion Slots
AGP8X (1.5V only)
3 x PCI
VGA
-Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards
Storage/RAID
2 x UltraDMA 133/100
Audio
Realtek ALC650 6-channel CODEC
S/PDIF in / out interface
LAN
Integrated 10/100 Mbps LAN controller + Realtek PHY
USB
Integrated 6 USB2.0 ports
Special Features
Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash
Back Panel I/O Ports
1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1
BIOS
4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2
Industrial Standard
PCI 2.2, USB 2.0
Manageability
WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion
Support Disc
Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility
Accessories
User's manual
UltraDMA cable
FDD cable
I/O shield
Form Factor
microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
SOURCE: Asus P5Ql board detects hd and dvd drive but when
It's very simple, the boot cd you are using is not bootable. End of story.
SOURCE: My Windows XP sp2 does not start up after the installation.
hi, I think you have not finish yet your OS installation, when installing OS just wait for it till you have see the start menu pop-up then there you go, you can now remove your installation CD. And express gate is a browser included in your ASUS motherboard that lets you boot up in seconds and enjoy your stuff even your OS is not fully loaded yet..
SOURCE: Help on Asus P5N32-E SLI Motherboard and hard disk
I am an advocate of ASUS boards..rock solid...Vista on the other hand...problems occur out of no where...when problems arise you always have to ask yourself" what has changed"..and work backwords from there.
http://www.aa1consulting.com
