when we havent even played the system we turn it on to play it we play for about 5 minutes then it shut off and two red rings come up. i understand the over heating issue. but how could dis be when the system hasn even been played
The cpu and gpu quickly gets hot if you have faulty fans and or the heatsink pads have disintrigated,
Try using a vaccum cleaner to remove any dust from the vents.
Listen and check for fans running and lastly you may need to do the x clamp repair mod.
If fans are running and all vents are clean and your warranty has expired on the console (check with microsoft), then go to ebay and look for x clamp repair kit and purchase the kit it should come with steel washers, heat treated nylon washers, screws and thermal paste. Make sure the seller also includes a guide on how to do the repair. These mods are pretty cheap BUT INVOLVES OPENING YOUR CONSOLE SO BE CAREFUL AND WILL VOID ANY WARRANTY.
My xbox won't turn on! I was playing it earlier then went to play again and the green lights dont go...
(More)
My xbox won't turn on! I was playing it earlier then went to play again and the green lights dont go on and the xbox won't start? i think it shorted out. what do i do?
problemen bij opstarten xbox heeft opslag stroom schoffel op te lossen bij aan zetten rode cirkel...
(More)
problemen bij opstarten xbox heeft opslag stroom schoffel op te lossen bij aan zetten rode cirkel code probleem stroom storing
display is black. all wires connected properly. game is working. can hear sounds of games just cant...
(More)
display is black. all wires connected properly. game is working. can hear sounds of games just cant see them
