Question about Dell 924 All-in-One InkJet Printer
How to change cartrige?
It's jammed and I hear a click when I try to print. I want to open the cartrige area and see if one of the cartridges is loose. I forgot how to open it.
  • yolita Dec 31, 2007
    I opened the cartridge area and there are no cartridges visible at all. The printer says to clear the carrier jam. How do I do that? I know little about the machine.
    I opened the printer as shown, but where #6 in the drawing is, there is NOTHING. Do the cartridges slide back and forth when printing? If so, then I think mine are under the #11 area and won't come out.
    Sergeant:
    Champion:
  • 298 Answers
  • Eugene Merritt Dec 31, 2007
    Close it turn ti off.Turn it back on
    and let it stop
    making noise and then open it
    and the ink cartridges cradle
    should stop in front of the opening
    Sergeant:
    Champion:
  • 347 Answers
Hi Yolita,
Here you can find the manual,
and Here you can try to fix your problem at Dells webpage,
If you still are having problems feel free to let me know.
Posted on Dec 31, 2007
  • 1 more comment
  • Santiago Vallejo
    Santiago Vallejo Dec 31, 2007
    Yolita i think a picture says more than 1000 words, let me know if you still have problems.
    (You can also try This manual if you didnt like the 1st one)
  • Santiago Vallejo
    Ah i forgot to tell you tu turn it on, (i supposed it was on,)
    BTW yolita culd you also rate me? I also helped, my fellow expert covered the setp of turning it on.
    thank you if you can,
  • Santiago Vallejo
    Yolita i saw you posted another problem with your printer. Do you still have the problem or did we already solved it?
Jam cartrige Area
Clear jams from the print-cartridge area
1. Open the print-cartridge door, and remove the print cartridge.
Figure 18: removing print cartridge
2. With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the product.
Figure 19: removing jammed media
3. Replace the print cartridge and close the print-cartridge door.
Figure 20: reinstalling the print cartridge
For any other Jam types Visit the following link : HP Lasterjet M1522
Regards,
Shrey
May 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
I'm trying to print and i always get a paper jam in door one. If I open the back door, the paper comes out 1 inch and stops. The paper is getting 95% printed on and then gets jammed. I changed the toner...
1. You have to clear paper feed roller
- to do this just follow simple steps:
- open fron cover
- remove toner cartridge
- use wet cloth (water or alcohol) to clear rubber feeder
- put toner cartridge back
- close front door
2. If the problem persist - chek all paper path sensors for lack of moving.
Oct 05, 2010 | Samsung SCX-4216F All-In-One Laser Printer
How to change the cartrige
1.Out tray (in down position)
2. press Power button
3. open top cover
4. raise cradle latch
5. lift out cartridge
6.Remove the replacement print cartridge from its packaging and carefully
remove the protective vinyl tape.
7.Insert the print cartridge firmly into the cradle. Secure the cradle latch.
You hear a click when the latch is fully secured.
8. Close the top cover.
If the Print Cartridge Status light continues to blink after installing a new
print cartridge, check the part number on the cartridge to verify that the
correct cartridge is installed.
Thank You
Oct 05, 2010 | HP DeskJet 920c InkJet Printer
Hp M1005 Laser printer showing no print cartridge while I've replaced a new cartridge.
hi
it means you have a paper jam
open up the tray, take the paper out and place back.
switch off printer and turn back on.
i have just found this on the internet myself and I have struggled for a week, but now ok...
May 20, 2010 | HP LaserJet M1005 Printer
Print cartridge stuck
Possibly what has happened is that one cartridge has popped out and is hitting the underside of the parking area.
In order to avoide damege to the tracking mechanism. make sure the power is disconnected, open the lid as if you are going to replace a cartridge, then with something strong and thin - a 6inch steel rule is probably the best - slide it into the parking area on top of the ink carriage. As you slide it in you may feel the loose cartrige. With a bit of jiggery-pokery (and some luck) you should be able to get the rule above the offending cartridge so that you can press it back down into place - you should hear it click.
Withdraw the ruler and reconnect the power and see what happens.
I've only seen this happen where 'compatible' cartridges have been used - it rarely happens with genuine carts (I think I've only seen it once or twice).
Let us know how you get on.
Feb 09, 2010 | Canon PIXMA MX300 All-in-One Printer
It starts printing, then stops, the printer cartrige is jammed
Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
Printer problem
It sounds like a bad encoder strip (ribbon cable). Uneconomical to repair.
Sep 25, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Expson CX8400 All-in-one printer
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Jul 11, 2008 | Epson CX8400 All-In-One InkJet Printer
My printer cartridge jams and it doesn't pick up the message from the computer
did you connect the cable correctly to your computer therefore the computer unable to pick up the message.
Jun 26, 2008 | HP Office Equipment & Supplies
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
