Graphics card i have an ati radeon 1500 graphics card it is installed and working but i cannot plug my monitor into it, all i get is a blank screen
  • eark Aug 21, 2008
    i dunno what exactly are the specs of the graphic card driver that i need but i have the same problem. i've just reformatted my laptop (compaq evo N800c) then the prompt says i need vga compatible video controller. the problem is i can't download such. everytime i attempt to do it, the net cannot display the can i resolve me please...tnx in advance and god bless!!!!!!!!!!AD MAJOREM DEI GLORIAM!!!
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
If their is a blank screen then how do you know that it is installed and working.
check the setup utility and select the VGA TYPE as AGP Vga card and save and reboot the system with monitor connected.
Posted on Jan 06, 2008
Monitor goes blank when trying to use radeon HD 2400 Pro graphics card
Well Michael,
it can be your monitor thats broke u can test it on a other system and see if the monitor works or not,if it works than u know its your graphic card thats broke and u should replace it
May 09, 2014 | ATI RADEON HD 2400 PRO Graphic Card
Hello, have Vista Home Basic. I just installed a Sapphire Radeon 7000 - Graphics Adapter - Radeon 7000 - PCI - 64 MB Problem: When I plug the monitor into the Radeon 7000, I get a black screen. If I...
Does the box say it is supported? These new 64-bit systems are still just getting going.
I tried xp64 but switched back because most of my hardware would not work.
Did it ever work? again alot of stuff is done with the 64 bit opsys.
Go into the bios, and make the new board the primary display.
In my experience, ATI needs to be primary. Just switch to PCI Primary.
If you haven't done this yet, you probably need to uninstall the software, too.
so it can setup correctly.
please rate this answer
Aug 10, 2011 | ATI RADEON 7000 PCI Graphic Card
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
May 09, 2009 | ATI RADEON X1650 Graphic Card
Blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
May 03, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Duel Monitor Problem
first thing first ensure that you have the latest ATI radeon X1600 pro driver and software installed else you won't be able to get the desired options for dual display under settings coz it will be working with generic drivers.
To download the latest driver and software click here
Then please click the following link :
ATI Radeon X1600 PRO How to
On this link click on the option
  • "Guides, Walkthroughs and "How to's"
Then opt for
  • "How do I use dual displays or TV/HDTV out? "
Just follow the instructions.
Feb 19, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
No post (blank screen) after intial driver install Acer 1716 LCD monitor
Please clarify something for me, after installing drivers, system reboots, and you have no POST information or startup screens at all?
Dec 15, 2007 | ATI RADEON 9550 Graphic Card
How to install ATI Radeon x1050 card to two screens on windows 2003
ATI can get confusing. You might have installed ATI's CCC, "Catalyst Control Center", along with the display drivers. I suggest you download the latest combo-CCC and drivers for your video card. ATI comes out with new drivers pretty fast. When using dual monitors CCC is where you want to setup your monitors. After you set up the catalyst control center you'll find it much easyer to assign what monitor displays what. One other suggestion. ATI will want you to uninstall any other software for your ATI card even though all you have is ATI software.
Driver site:
ATI's uninstaller utility:
Nov 28, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
