my router is plugged in, all connections are fine...my laptop shows me as being connected but i cannot access the internet. I am wired right now but would like to use my wireless please help
I've been on a Dell XPS system and bought an IMac. During setup of the IMac I cannot find the router...
(More)
I've been on a Dell XPS system and bought an IMac. During setup of the IMac I cannot find the router nor remember the password. Any suggestions?
Hi, I am not sure, but I think that I've got the same/similar problem...just with my iPod and...
(More)
Hi, I am not sure, but I think that I've got the same/similar problem...just with my iPod and iPhone! In my house (3 levels + celler) I use... - FRITZ!Box Fon WLAN 7270 (UI) Firmware-Version 54.04.76 (IP 192.168.178.1) My main router, which is connected to the internet and on which all other components/clients are connected to in my home-network. He is located in my 3rd level (office). - DELL TM 2300 (IP 192.168.178.2) Firmware-Version 5.1.1.6(1/31/2004) He is in use as a Wireless Access Point, located in the living room (1st level) and connected through LAN to the home-network (FRITZ!Box). My initial idea was to use the WLAN function of both routers with the same SSID in my house, so I could walk around/up/down with my notebook, which would always connect automaticly with the router with the higher signal strength (e.g. 2nd floor with the FRITZ!Box from the 3rd floor, as the ceiling in the 1st floor is made out of concrete). It did work at the very beginning, as I was installing my Access Point in my living room at the very end and after I saw that it works, I was really happy! I jumped up, got my notebook and run upstairs to check/see how it's going to switch from the DELL to the FRITZ!Box...it worked as I said, but when I got back to the 1st floor, I recognized that the signal strength in my Task Bar got lower...not to say almost to 0! It didn't switch to my DELL. I tried it several times, but without any success. A friend of mine told me then, that he is very sure that the DELL isn't able to do this switching thing...however, the result is, that I unabled the WLAN function of my "better" router FRITZ!Box and use only the DELL to connect my notebook to the network. It works without any problem...so far so good... But after I bought my self an iPod and iPhone, I have problems with the WiFi connection to my Access Point (DELL)! They are connecting perfectly with him, but after a few minutes the connection cuts off and I can't surf the web or in the App-Store of my iPhone/iPod. The only thing I can do, is to unable the WiFi connector in my iPhone and enable it after 1-2 sec. again. After that it works again, but a few minutes later...the same story. So after I read this post here, I thought it might be a similar or even the same problem. I am also using my notebook in my living room...I tried to shut down the notebook and use just the iPhone, but it still has these cut offs!!!! I really don't know what else I could do...of course I thought of buying me a new router/Access Point, but I still don't want to believe that this is it...there must be a solution!? ;) Please let me know, if somebody needs more information, to be able to give me a hand for this problem! Thank you very much in advance... See Ya, Toni
When installing anew computer, everything but the router worked fine. I used the original install...
(More)
When installing anew computer, everything but the router worked fine. I used the original install disc and ; the router lights come on but the computer doesn't see it. Can't set it up.If I hard wire from the cable modem to the computer, everything is fine.
The Dell router will not communicate with the Comcast modem. The modem is working properly. The...
(More)
The Dell router will not communicate with the Comcast modem. The modem is working properly. The router is working properly with the exception of the error message "not connected to the internet." Comcast has verified service. I downloaded the latest Dell driver. I do have internet service when directly connecting my computer to the Comcast modem.
It has worked okay for 2 years, (every once in a while it would cut out-and I could only access...
(More)
It has worked okay for 2 years, (every once in a while it would cut out-and I could only access internet through the DSL modem. After 2 to 7 days, I would reinstall the router and I'm back in business. After 9 months it's stopped again, (power and internet signals are steady while LAN signal blinks---power,internet and LAN signals on modem are steady). Resetting hasn't helped, and trying to reinstall the router hasn't worked. In fact the installation program had to be aborted because it couldn't find the signal after cables were connected to router. What can I do next?????
