Washer won't run
My Kenmore 80 series washing machine won't run. It stopped in mid-cycle during the spin mode. There is power to the outlet. I removed a few clothes, in case it was overloaded, but now there is only a twin size comforter in there (it's never had a problem with it in there before). What else must I do?
Joel
  • 1 more comment
  • DrJRB Dec 31, 2007
    Okay, it does fill & agitate, but I'm not sure if it will rinse/spin when it reaches those cycles.
  • DrJRB Jan 01, 2008
    It worked only for a few minutes in the wash cycle & shut off again. I plan on fixing it myself, if it is not too complicated. Can you walk me through it?
    Thanks!
  • DrJRB Jan 04, 2008
    Is anybody there? Can someone walk me through replacing the lid switch on my Kenmore 80 series washing machine (since that may be the problem, see above)?
    Thanks,
    Joel
    President:
  • 1,314 Answers
Pull your comforter out go back to wash see if it fills and agitates let me know
Posted on Dec 31, 2007
  • robert samples Dec 31, 2007
    proably not proably has a bad lid switch this is how we find out are you going to fix it your self if so ill walk you through it
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 20, 2012 | Kenmore Washing Machines
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
266 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
