Question about Maytag MSD2732GR Side by Side Refrigerator
Maytag MS2732GRW ice maker quit
Seems to be a electrical/water problem. Ice tray does not fill with water. All other water on frig works. There is water in water line to back of freezer. Bad water valve? Bad Switch? I turned the unit off for several hours thought maybe it was freezing up no help.
  • 1 more comment
  • Anonymous Dec 31, 2007
    took whole tray out to pour ice into big pan and now has stopped producing ice
  • working55 Jun 25, 2008
    I have this problem; my ice maker was working fine a few days ago, all of a sudden there was no ice. The water is working on the door and the lines have water. The filter light has been on ever since I bought the house with the appliances about 18 months ago. I just read on line how to make the filter light go off; but now I am concerned because I do not know where the filter is located and I am sure it needs to be replaced. Can you help?
    Thanks,
    Working
  • Anonymous Mar 20, 2014
    The Ice Maker does not seem to be filling with water - suspect that there is something wrong with the ICE WATER PRIMARY SOLENOID VALVE as there is no water going into the tube form this point (although the supply tube to it is full of water).
Ice freezes in storage bin
Posted on May 16, 2008
    President:
  • 1,314 Answers
Guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Posted on Dec 31, 2007
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Maytag MSD2732GRW ice maker quit.
Hi dsandcs, how many water supplies does your fridge have?
I mean if you look at its back can you see one or two plastic tubes? (that transport the water to the frigde)
Dec 31, 2007 | Refrigerators
Ice Maker Doesn't Work
Is there ice in the ice tray? If so the heater is not working to allow the scooper to push the ice out into the tray. If no ice in tray then the fill solenoid is not opening to allow water into the tray. Replace the solenoid.
Sep 19, 2017 | Refrigerators
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
Maytag MSD2454GRW ice maker won't fill with water. I checked electrical connection. It seems to be secure. Also, water comes out of the door like it should. The ice maker just won't fill with water.
OK, Most times that would be the ice maker when they have an electronic module. Pour water in ice maker trays and let freeze. If it freezes and dumps but does not refill then the water control valve for that side is defective. If the cubes just sit there then for sure ice maker core.Let me know what happens and I will return soon with part numbers and locations, Thanks, Sea Breeze
Mar 15, 2010 | Refrigerators
Ice maker no making ice.water not filling tray
you have a bad water inlet valve located on the back bottom of frig behind the bottom panel-mike
Jan 26, 2010 | Kenmore Refrigerators
Ice maker quit working on GE refrigerator
Sometimes on a ice maker what will happen is the water line that fills the ice maker will freeze. You can use a large syringe filled with hot water and from the rear of the frig remove the water line where the hose goes into the rear of the frig and force some hot water into the tube to see if it is clear.
If the line is clear fill the ice maker manually and see if it goes through a cycle.
If it goes through a cycle you have to check to see if the ice maker is calling for water by putting a multi meter across the contacts of the water inlet valve located behind the panel on the back of the frig. Advance the ice maker to run through a cycle and see if it is calling for water. If you have current going to the valve and no water momming in, replace the valve.
If you do not have current going to the valve after the ice maker has gone through a cycle. Replace the ice maker.
Dec 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker over flow now water wont fill back up
no its not blown up low water pressure will cause also sticking water valves if it has worked properly for a while then change the water valves
Jan 29, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker not working
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MSD2732GR Side by Side Refrigerator Logo
392 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
