I have a probloem with my Gagia Cubika. This is about 30 months old and gets used about once a day. When I switch it on, the middle light, that should glow when the water is hot enough to brew coffee comes on immediately and the water won't heat. I can still produce hot water and steam with the steamer button though. I'm guessing it has two thermastats and one has broken?
We are going descale our baby gaggia machine but cannot remove the shower disc screw... Too tight......
(More)
We are going descale our baby gaggia machine but cannot remove the shower disc screw... Too tight... What safe product do you recommend we use to lubricate the screw? Any other suggestions about descaling? This is our first time, as the water way too slowly and burning our espresso...
Thank you so very much for your time and advice,
Shoshana
Had low pressure so de-scaled machine. Now water only comes out of one of four holes in the head...
(More)
Had low pressure so de-scaled machine. Now water only comes out of one of four holes in the head when shower screen removed. Is this normal? but pressure seems ok when brewing coffee.
my apologies, it is not a "classic". It is an "espresso" $235 at WholeLatteLove...
(More)
my apologies, it is not a "classic". It is an "espresso" $235 at WholeLatteLove 5 years ago. It has been regularly descaled and I use filtered water. Pump works, on-light works. Boiler won't heat up.
I have a Gaggia Classic coffee machine which I haven't used for some time. I filled the resevoir...
(More)
I have a Gaggia Classic coffee machine which I haven't used for some time. I filled the resevoir with water turned the machine on and primed it, but hardley any water flows through...any suggestions?
