Question about Averatec 3200 Notebook
Averatec laptop 3220 won't recpgnize system password to change boot drive
    Novelist:
  • 101 Answers
Hi Dmelch,
Assuming you set one, if you haven't don't put on in, and see if the password is nothing, (leaving it blank). If not, you have to pull the battery, disconnect the power, remove the larger panel on the bottom, and unplug the system battery there. Wait 10 min, reassemble and try it.
The other way is to get a program that resets the Bios password, to blank, This Cd has the program, and is one of the best I have ever used, http://www.powersolutionscd.com/pw.htm
Another one is here, which lists a lot of "backdoor" password that work on most bios's. http://www.tech-faq.com/reset-bios-password.shtml.
Posted on Jan 07, 2008
Averatec 2100
Remove the usb disc. If it boots you need to go in to the bios and change the boot order to hard drive first then usb etc.
Dec 13, 2013 | Computers & Internet
Windows xp
I recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows xp password , there are only four steps as follow:
Step1: Download Windows Password Reset and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove Windows password on the operation interface and logon PC without password.
Jun 21, 2012 | Averatec Computers & Internet
Please help me....if how to reset the HDD password of my netbook (averatec N1140 Series)...
You can reset netbook password by Smartkey Windows Password Recovery, just do as the following steps,
Step1: Download Windows Password Recovery Enterprise and install on any available PC.
Step2: Burn Windows password reset CD/DVD or USB to reset lost Windows password.
Step3. Set your locked pc BIOS to boot from CD/DVD-ROM or USB Flash Drive.
Step4. Reset lost Windows password to Re123456 together with the burned CD/DVD or USB Flash Drive.
May 21, 2012 | Averatec 1000 Notebook
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
MEDIA TEST FAILURE SELECT CORRECT BOOT DEVICE
Enter the setup of the system and change the boot order to Hard Drive.
Aug 21, 2011 | Averatec 4200 Notebook
I have an Averatec 4100 and I would like to set it back to factory default settings. How do I do that?
You don't say if the system will still boot up, or if the Hard Drive is still intact or what happened that you want to restore to the factory settings.
If the hard drive is still OK, you may be able to restore the original software by pressing f4 repeatedly on a power up reboot, before the Windows system starts loading (a 3200 uses f4 on boot-up to access a hidden partition (D:?) on the hard drive which may contain the original system files and applications. The 4100 may not be the same.)
If you have modified the drivers, you may be able to restore the original drivers by going to "My Computer" icon on the desktop, and right clicking to open the "system devices" menu. There, you can open "properties" for any devices (hardware) that you may have changed, and try to restore to the previous driver.
If you need new (original) drivers, you may download them from:
http://www.trigem.com/us/support/drivers.asp
The user manual for your system is available at:
http://www.retrevo.com/d/ds/progress?doc=620637ea9665f6ec226b353b2ed6df5e&rk=0.5734748288133472
Other options, such as a recovery CD is available for a small fee at:
http://www.user-guides.co.uk/cddownload/Averatec/Averatec4100/Averatec-4100-Data-Recovery-Boot-Disk-CD-For-Windows-98-548371.html (you have to follow the instructions to download a .iso image file, and burn it to a CD, which may be a challenge for you if you have not done that before).
If these options don't work, or you need help, provide some more information on what happened to your laptop and what is not factory any longer.
Apr 12, 2011 | Averatec Computers & Internet
Forgot password to logon
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Sep 17, 2010 | Averatec 3120V Notebook
I have averatec 3200 boot failure how to rboot it
Boot failures are generally caused by the system not seeing the hard drive or not being able to read it. You should enter the system bios and see if it can see the hard drive or see if the system sees it while booting up. It could just have some bad files or bad sectors. Where it's in a notebook it probably doesn't have a bad connection. You can also boot off your system CD and choose recovery and see if you can see the hard drive.
Nov 07, 2009 | Averatec 3200 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Happy New Year! How to Bypass Password
what o/s if xp home boot into safe mode
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 29, 2007 | Averatec 3150H Notebook
Averatec 3200 Notebook Logo
131 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
