Question about Kenmore 63252 Microwave Oven
Kenmore Microwave 63252
After a power outage the unit does not power on at all.
  • 579 Answers
Microwaves use a special ceramic fuse that has probably been popped by the outage. You have to take the cover off and it looks just like the regular cylindrical glass fuse except this one is white instead of clear. I think radio shack has them. Hopefully the fuse stopped the power surge before it got the front panel controls.
Posted on Dec 31, 2007
Mine was made july of 2007 so it would be under warrenty then
Typical warranty is 1 year parts and labor and 3 to 5 years on the magnetron tube only. BTW, what's wrong with this unit ??
Oct 09, 2013 | Kenmore 63252 Microwave Oven
Kenmore microwave runs but wont heat
Hello there:
There's no heat, When the microwave won't heat, soemtimes you will get a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. We recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
Oct 05, 2010 | Kenmore 63252 Microwave Oven
Is there a fuse location? light work timer runs commands are working but fan does not come on.
Normally a blown fuse will make the entire unit "dead".
But it of course depends on your model number.
May 29, 2010 | Kenmore 63252 Microwave Oven
63252 / 63259 1200 Watts Microwave Oven: Turns on but,wont heat up...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 07, 2010 | Kenmore 63252 Microwave Oven
Kenmore 63252 / 63259 makes buzzing noise during use from control panel side of microwave
transformer probably has a loose fin or 2, it should still work fine but will get louder, I don't think its worth buying a transformer for that mw
Feb 06, 2010 | Kenmore 63252 Microwave Oven
I have the 63252 model....When the microwave is turned on to cook, it runs, there is no heat.... does this microwave have fuses of any kind....
Your oven may have separate fuses for the magnetron and the electronics so I suggest you pull the plug, remove the back and look for an accessible fuse holder. Allow the unit to stand unplugged for at least several hours before removing the back panel as there are components inside that can carry a nasty charge for hours.
Feb 26, 2009 | Kenmore 63252 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Touchped not working
What is the complete model # on the sticker inside the microwave?
Oct 11, 2007 | Kenmore 63252 Microwave Oven
LCD Display not working, everything else is
If microwave works even if lcd is out then a 100% that the microprocessor is working. Try to check the lcd driver for any loose connections, the bus cable linking the board to the lcd disply for any breaks or try replacing the lcd itself.
Feb 18, 2007 | Kenmore 63252 Microwave Oven
Kenmore 63252 Microwave Oven Logo
291 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
