Cars & Trucks Logo
Anonymous Posted on Oct 25, 2009
P242F Bank1Sensor3 sprinter fault codes 07 Sprinter 2500
Hi Guys, Can someone tell me if you've seen or know what this error means or how can it be fixed :(
Here is the full code: P242F Generic Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3.
What's Bank1? or where it is?
Thanks so much
  • Anonymous Oct 25, 2009
    its V6 engine 3l Diesel. But how can I tell which cylinder is 1? :(
Jon Adamson
Level 2:
Sergeant:
  • Dodge Expert 167 Answers
  • Posted on Oct 25, 2009
Jon Adamson
Dodge Expert
Level 2:
Sergeant:
Answers
167
Questions
Helped
101342
Points
508
Bank one is the side on a V or H engine where cylinder number one is located. On an in-line engine you only have a bank one, no bank 2. Sensor 3 will be the third sensor from the engine in the exhaust stream.
Testimonial: "That was extremely fast answer :)"
  • Jon Adamson
    Jon Adamson Oct 25, 2009
    I don't have access to info on Dodge products but most use the left bank (as viewed from the driver's seat) as #1.
2answers
What DOES code 36d with wrenches mean for a 2013 Mercedes sprinter
LOST THE USERS GUIDE IN THE GLOVE BOX
IT MEANS IT NEEDS SERVICE , IN A SHOP.
WRENCH CODES ARE HUGE ON THIS CAR.
LOST FREE MANUAL IS HERE
https://sprintermanual.com/wp-content/uploads/2017/12/Sprinter-Van-Operators-Manual-2013.pdf
FOR ALL I KNOW THE WRENCH MEANS OIL CHANGE NAG
OR ASK HERE ON A REAL MB FORUM
POSTING PHOTO OF ANY ERROR IS MAGIC,
YOU GET THE TRUTH, FAST.
WE CANT SEE YOUR DASH OR FIDDLE THE BUTTONS TO SEE ALL ERRORS
ASK HERE IS BEST, SPRINTER ONLY FORUM..
https://sprinter-source.com/forums/index.php?threads/73896/
1helpful
Two OBDII codes. How to fix?
P0101, mass air flow circuit range, P242F appears to be a non code , may mean don't forget to repair previous code. Check and repair mass air flow problem . then delete code, code will reappear if fault not fixed.
2helpful
Hey guys, I have a 2008 dodge sprinter 2500 throwing a code P242F auxiliary emission controls and P0227 TPS switch c circuit low imput. I replaced the TPS, but i'm still on reduced power and still throwing...
Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
p242f is bogus try typing that 1 more time.
my wild guess, is you dont have FSM or access to alldata.com?
and guess 2, (im too lazy to look it up) its a flyby wire car?
if yes, then you need training on flyby wire, its COMPLEX.
guessing and throwing parts is very expensive on FBW, 10x so.
if you know understand FBW, then read the FSM ,it covers all this in great and complex details.
FBW is, you tell ECU how fast you want to go, and it does ALL that magic. (short version)
do you want guessing, or real tests.
say so please.
for $15 low bucks , you can read all night, and be ready in the morn.
discounted here,
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
btw2, are you going to spend $2000 on parts.
just to find an air leak?
here is the #1 rule for EFI,
the ECU/PCM NEVER !, knows what part is bad!
it only knows what monitor test failed (DTC'S)
that takes a human, to conduct more tests to find truth.
this is a fact. knowing this one fact,would make most parts
stores go broke fast... .I promise.
2answers
What is a particulate filter?
Hi there a Particulate Filter is a device fitted to diesel vehicles that remove soot from the exhaust gases exiting the engine, they are normally located under the vehicle between the downpipe and back box.Hope this Helps
1helpful
I bought 07 dodge sprinter 2500 3.5lts. 2 days ago & i have ck. engine lt. dtc is p0019
crank sensor /cam sensor corrolation codes meaning one was changed and the system wasn't relearned
2answers
Error code that was stored was "voltage circuit C low". What is this? 2006 Dodge Sprinter 2500
i could help you better if i had the code #s, check the battery and the charging system.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
