Question about Refrigerators
Maytag MSD2732GRW ice maker quit.
It is no longer making ice. Seems to be a water issue. Tray never fills with water. All other water on frig works. There is water in line going to back of freezer. Electrical problem?
  • dsandcs Dec 31, 2007
    Supply line comes in to valve? then up to back of frig to filter. then back down to another valve with two outlets one for water at door which works and on to ice maker.
    no I
    Sergeant:
    Champion:
  • 347 Answers
Hi dsandcs, how many water supplies does your fridge have?
I mean if you look at its back can you see one or two plastic tubes? (that transport the water to the frigde)
Posted on Dec 31, 2007
  • Santiago Vallejo
    Santiago Vallejo Dec 31, 2007
    dsandcd, did you already solve the problem your fridge had?
  • Santiago Vallejo
    If your fridge have a ice maker switch, check that its on,
    *Does the back of your fridge have 1 or 2 plastic tubes?
The whirlpool I have is a side by side if have a bottom drawer freezer. And my ice maker is in there .my light switch stop working so I replaced it so now the light comes on when the drawer is open...
If no ice check to see if there is water in the tray. If no water in ice maker tray issue is with the fill solenoid. If water in tray the heater is no good and the ice scooper cannot move the ice from the tray to the bin. If you want you can just replace the ice maker on ebay for cheap
eBayeBay
Sep 23, 2017 | Whirlpool Refrigerators
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
My ice maker quite working. I think there is issues with the water getting to the icemaker. If I pour water into the tray then it will make it and dump it out, but it never fills it back up. The water...
The water solenoid that supplies water to the ice maker has gon bad. The reason the door dispenser still works is because the refrigerator has a dual solenoid. You will have to replace the solenoid in the rear of the refrigerator located behind the pannel on the bottom of the unit itself. Look for where the main water supply is atatched. Please rate my knowledge and ability on this web sight. Thank you.
Sep 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker no making ice.water not filling tray
you have a bad water inlet valve located on the back bottom of frig behind the bottom panel-mike
Jan 26, 2010 | Kenmore Refrigerators
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ice maker not working
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
