Question about Viking VGSC306-4B Gas Kitchen Range
HOTPOINT OVEN Hi I have an oldere Hotpoin STove-oven. Everything turns on but the elements do not heat up enough(warm to touch) and its electric? Any help please? Thank You Sandra
    President:
  • 1,314 Answers
Id say you have a power problem in your outlet or power Cord if you have an electric meter i can walk you through test procedure if not have the outlet check each element is on a separate circuit the only i can think of that would affect them all would be a power problem you can try to turn the breaker for oven off then on
Posted on Dec 31, 2007
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Hotpoint oven not heating up;broiler ok
the element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Jan 19, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work
I assume the oven has worked at one point? Does the broil still work?
This is my experience with my White-Westinghouse gas stove:
The igniter bar is toast. There is 1 igniter bar each for the bake and broil (1 on top, 1 below). This is instead of a pilot light. Its an element that heats up to be hot enough to ignite the gas. If it doesn't get hot enough, the gas does not turn on and therefore not heat.
I went to my store and asked about this. "90+% of the time, that's the problem" So I bought a replacement and installed it myself. Problem fixed. Just had to undo a few screws to get at the bar, then connect the new one's wiring under the stove using marettes & some electrical tape, but the rest back together and that was it. I think the part cost me about $60-80 here in Winnipeg a few years ago. But it would've been at least that just for the guy to show up to look at the stove, never mind fixing it.
Dec 04, 2008 | Hotpoint RGB528 Gas Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Viking VGSC306-4B Gas Kitchen Range Logo
79 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
