Whirlpool LSR7233EQ0 Washer Leaking
It appears to be leaking from the center of the tub so either the tub or the tub seal. I have a diagram it appears that i need to take it apart from the top down? If this is right are there any particular things I should know Like how does the top of the agitator cover come Off?
    President:
  • 1,314 Answers
Just pull it off.on the control panel you will see two screws on the front or back back them out as far as you can then pull the control panel slightly forward then flip it back there are two gold clips on the body of the washer with a screw driver holding the handle pointing toward the back pop the two clips off but remember how they go as it can be tricky putting them back on if you don't then tilt the washer at about 45 degree's and pull it forward disconnecting any wires you see then take the body of the washer off and you can start working you will need a special wrench to get the tub block nut off or a small pipe wrench and hammer will do can get wrench fairly cheap at an appliance parts store now when you put washer cover back on tilt to 45 degrees and look down .the front of washer goes under frame and the sides go on top there are two rectangular slots that fit on tabs on the frame look close and you will see
Posted on Jan 01, 2008
Washer leaks when in use,in rinse ..
see this causes and diagram. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Sep 30, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
The washer is leaking from the bottom
Your center seal is going bad or you have a bad hose, leaking water pump, or a cracked tub but GE is notorious for there center tub seals to going bad I would recommend a qualified service technician come look at it to rule out which one it is if your centers tub seal is bad I would buy a new washer but sorry for the troubles.
Jan 22, 2011 | GE WBSE2090A Top Load Washer
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
My estate washer is leaking water when we turn it on. It is not holding any water in the tank. Any suggestions what I should look for and fix myself. Thank you
If the washer leaks when you turn on check these:
* Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
* Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
* Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
* Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Sep 02, 2009 | Whirlpool Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer LSQ8500JQ0 leaks water/not leaking from hoses.
The other likely leaking points are the pump itself or the center post gasket - Main outer tub seal.
Regards
Please rate this solution
Sep 24, 2008 | Whirlpool Washing Machines
Washing Machines Logo
368 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
