Question about Panasonic SC-HT720 System
Cd not playing
When i insert the cd the disk is not picking up into the sleeve or chamber.I did purchase a disc to clean it but still does not work.
  • Rob344 Aug 24, 2008
    I have the same problem, any idea how to fix this?
  • 165 Answers
You need to take to the repair shop it needs service on the pick up laser and sensors
Posted on Nov 17, 2008
Pioneer PD-M550
The player have problem with the laser pickup unit.
Try one thing, there is a disc available for cleaning the laser pickup unit (). You will get in any cd shops(instructions will come with it). Buy the cd and the insert it in any one of the tray. It will clean the laser unit if there is any dust in it. After cleaning put a disc and check is the problem remains. If the problem remains the you have to change the laser pick up unit. You can fin a link here which will lead you to the laser pick up unit. You will get the part only against confirm order.
PEA1030
Laser cleaning CD
Ajin
Jul 24, 2012 | Audio Players & Recorders
Dear sir. I have a new new Samsung BD-D5700 dvd blu-ray disc player an the problem is, that when I insert a dvd blu-ray disc or a CD disc it's okey, but when I insert a NO blu-ray disc the system gived...
if the red ray disk is not playing in the system that means there is some problem with pick-up assembly. u need to open the cover, clean the pick-up assembly's lens very gently. if that does not work that means you have to replace the pick-up assembly first.
Sep 22, 2011 | Samsung Televison & Video
CD's will not play. I was playing a CD with no problems and in the middle of the CD, it just quit. I tried other CDs which have worked fine in the past and now I can get nothing to read. It will say...
hi,
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the CD and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to replace the same.
ok
Mar 16, 2011 | Bose & Wave& Music System
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    My cd-dvd drive does not recognize discs, so movie discs are not played when I use Win Media player. I insert a disc and there is no automatic recognition of inserted disc.
    You should clean your CD-Drive lens with Disk cleaner Cd that will work or move anticlock wise and your problem will be solve after cleaning the lens.
    Good Luck
    Nov 30, 2009 | Fujitsu Siemens LifeBook® S7110 PC...
    My disk drive is not reading the cd. I have tried blowing it out, but it just shows that it is trying to read the disk then stops thinking.
    Clean smudges off of disc with microfiber cloth and a little water.  Disc will not play if heavily scratched.  Insert different discs isolate the problem.  If other discs won't play, then you optical disc reader is fu.k.d up. Get you a CD disc cleaning kit from one of those box stores and try cleaning the optical reader that way.  If that don't work, then you need IT to open this puppy up and replace the optical drive.  Do it yourself if your IT.  Order the optical drive for cheap on e-bay.
    Oct 30, 2009 | Computers & Internet
    Player shows '' No Disc'' even when inserted with a disk
    When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
    Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
    See also the following websites on how to clean the lens, use a cleaner disk first:
    Gizmo Highway DIY - Clean your CD player lens
    Lens Cleaning CDR CD-RW (how?)
    DVD Not Working
    Mar 04, 2009 | Sony Televison & Video
    Ht-x30 samsung cinema system display unknown disc
    TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
    (please use The ratings to keep this site free!)
    Dec 14, 2008 | Samsung HT-X40 System
    23HCV87 DVD problems
    May be dirty lens get a cleaning disc for cd player and insert to clean then try player again. If you can take cover off insert disc see if disc spins,if not spinning you need a motor drive.
    Nov 24, 2007 | NAD C320 2-Channel Amplifier
    Panasonic SC-HT720 System Logo
    49 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
