Home | Mitsubishi | WS-65809 65 in. Rear Projection Television | Problem TV, mit...
Mitsubishi WS-65809 65 in. Rear Projection Television
Problem for Mitsubishi WS-65809 65 in. Rear Projection Television
Problem TV, mitsubishi 1080i 65"
By youngpm2 on Oct 25, 2009
Problem TV, mitsubishi 1080i 65" wide screen projection CRT model wide screen A65. Two problems: 1. TV displays all colors but has trouble holding proper zoom level, picture seems to dance back and forth, zooming and zooming out. movement is not extreme but noticeable on any channel with ID/logo in any corner. Problem occurs on all inputs, DVD, satellite, PC input 2. Unit began powering off by itself, not input required. Unit began powering off faster and faster. Visual inspection revealed no cooked components, all looks to be intact. Unit was dusty inside but not severe. Minor vacuming/clean required. Power feed is thru Monster power filter, clean power 100% of unit history. Problem began this morning. Any assistance would helpful. Regards P. Young
Comments:
Oct 25, 2009
- Thanks.
Best Solution
posted on Oct 25, 2009
Very Helpful)
pabloloco
Rank: Guru  Televisions & Videos  Expert
Rating: 94%, 222 votes
It sounds like you have a 'blooming' problem. Blooming is caused by insufficient high voltage to the anode of your CRT. The low high voltage allows the beam of electrons to spread too wide and thus create a picture larger then the screen, to the point that the screen appears to "bloom" especially on bright or white screen scenes. The cause of the low high voltage can be the horizontal output transistor, the damper diode, the safety capacitor, the flyback transformer, and any of the associative circuitry of these sections of the TV. I advise that you have a qualified TV repair technician examine and repair this TV.
Popular Solutions for Mitsubishi WS-65809 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65809 65 in.
Do you recommend Mitsubishi WS-65809 65 in. Rear Projection Television?
Answer
Answer
my tv takes a while to tune in when i first turn it on,then it kicks in and after a while it tunes... (More)
Answer
I replaced the bulb in my 65 Mitsubishi tv and it still wont turn on.
Answer
There are many lines going through the tv picture and they flicker and move horizontal
Answer
shoot off tech said color bulb burnt with a little water damage
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-65809 65 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
