Question about Zenith Z25A66R 25" TV
Zenith System 3 25" no audio picture ok
Problem with a console unit which has all channels and no sound.
Tried to connect external audio unit and no sound. any ideas>?
tswlms@aim.com
  • 373 Answers
If you have satellite try unplugging satellite receiver. If doesn't work you probably have a audio output ic bad inside the set.
Posted on Jan 05, 2008
My zenith surround goes into protection mode after 15 minutes no sound
Disconnect your speakers when unit off and cold. Turn unit on and wait. If unit stays on, check speaker wiring for damage. Connect one speaker at a time with unit off and retest to find either a bad speaker or output channel problem. Repair speakers and wiring if found, or take unit for service, you have an overload problem.
Nov 22, 2017 | Zenith Audio Players & Recorders
Toshiba television/vcr combination
Also try changing the TV system's selector..
Mar 03, 2008 | Toshiba MV-13N3 Television
Headphone distortion and a hum sound feedback issue when using external speakers
Sometimes empty/unplugged channels introduce noise to the amplifier. You can always try to connect all of the input channels to some external mobile phone/mp3 player, etc. and then set these equipments to the minimum possible volume (mute if possible). This should remove the "atmospheric" audio noise.
Dec 27, 2013 | Hercules DJ Console RMX
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Dec 04, 2012 | Zenith IQB50M90W 50" Rear Projection...
I have no sound from Xbox HDMI connection.
you likely connected it with one or both units involved on and HDMI does not like that--prone to all sorts of audio issues.
If in doubt unplug the units and wait and plug back up making the connections first.
Jun 07, 2012 | Zenith " 50"" Class - Plasma - 720p -...
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
How to connect my nintendo 64 to my hdtv i have the connection which i should put the channel in either 3 or 4 but it doesnt work so what do i do
OK you do NOT use "Channels" This unit connects Via AV, Audio Visual, You must select, Auxiliary, External, or whatever your "External" inputs are called. Select the correct one, you will be all good.
Feb 12, 2010 | Nintendo 64 Console
Sound
I do not have a Zenith B25A02Z TV. What I do have is a 1988 Zenith Color TV SE2517P. I called a local tv repairman and discussed the problem over the phone. He can take a look at it if we bring it in (service call to the home cost $100 just to show up). He said it was worth fixing since he thought it was only the sound. We have a great picture. He charges $20 to look at it but we have to leave it. He lives 20 minutes away one way. We think it is worth the trip if we can get it loaded into our minivan. We live in western NY where the weather can get pretty ugly many days. I will post the solution later when I know. FYI
Dec 30, 2008 | Zenith B25A02Z TV
No audio for tv?
Since not all devices have the same in/outputs available, if you are trying to interconnect them, it helps to know the make and model of both, not just one.
There are several possibilities to connect external devices to your 'home theatre' system.
The one we have delivers the best when S-video is used but that requires a separate path for sound.
The standard colors for audio in and outputs are red(=right) and white(= left) and often cables are supplied with the same color coding.
The usual connections will be named 'Line in' and 'Line out.' The outputs deliver specified voltage into a specified load (or termination) and the inputs expect that condition.
This ensures that volume controls act in a sensible manner.
Sep 05, 2008 | Zenith XBS444 System
RCA 5.1-Channel 250 Watt Home Theater System - Model RTD209
Unit was working fine,took a movie out,put in new one,but would not play.Tried hitting open button ,unit will not respond,all other functions working ok.
What could be the problem,is it worth fixing?/Is there a reset button somewhere on unit?
Oct 27, 2007 | RCA RTD209 System
Televison & Video Logo
56 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
