Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du
Duet washer and Dryer 4 years old
posted by devkirn on Dec 31, 2007
I have a duet washer, it does not seem to be spinning like it should.  I have not had it serviced since I got it four years ago.  The dryer was just moved from its original spot in the laundry room, has flex duct that goes about 30 feet under the house, not the best way, but the only way I could see to vent it.  The dryer is now taking a long time to dry and does not seem to be getting very hot.  Should I call in the service person to look at both of them or what? Thanks, devkirn
Comment posted on Jan 01, 2008
OK, I fixed the dryer myself.  Just like a vaccum cleaner a dryer does not work well when the duct work is clogged up.  I went under the house and cleaned it out. Then I could feel the heat coming thru the vent and sure enuf it dyed like crazy.  I still am not sure about the washer, but I have an idea that it needs to be tuned up...if anyone has ideas about it. Thanks,
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 13, 2008
Not Rated (0)
Coldcut
Rank:Wiz Wiz
Rating: 84%, 559 votes
open the bottom access panel , 3 screws on bottom front,
open the filter trap and clean, it will dump some excess water,
you didn't explain the spinning issue well , not spinning fast , noisy, no drainage etc....
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Duet washer and Dryer 4 years old:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
We have a 15 year old top load Maytag washer that will...
Bosch 3.81 cu ft Nexxt 500 Plus Series...
We have had our 500 plus series washer and dryer for about...
The time during washing cycle jumps from original start...
Hi I saw your answer and wondered if you could help. On my...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
