The TV might need a soft reset which is unplugging the power cord for 60 seconds and plug back. Try that, Or the worse case is that the MAIN BOARD inside the set needs replacing which I just did an online search and found none available.
Check the remote control for its infra-red emission.Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV.If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/If the remote control is found OK; check and replace the infra-red sensor inside the TV.Contact any service technician.
resert the r.control, e introduce again the code. Please see the picture attached use digital camera or webcamera the LED must TURN ON, otherwise open the keypads and clean it, clean the contacts battery and replace. God bless you
Hi, this Konka remote is not a universal remote and cannot be programmed to any devices. It only works with the original Konka TV. To purchase a new Konka remote for you Konka TV you can go to Replacement Remotes.
Visit this site for more details.Type in the site name Electro-help either to Google or Yahoo search box and click search.It is an electronic equipments service help site.All details you want are there.Note the position of hyphen in between words in site name, when you type it in.The site will appear as it is in web. Find out codes for Konka from the code list provided by this site. Pull up older posts there. Buy one universal remote control, which has setup codes for Konka described above. all setup proceedings also described.
me too help [email protected] Do u need remote to set speakers along with other setting problems including, back speakers not working, tv not on surround sound, can play dvd and tuner still no back speakers, no remote. Do u need remote to set, please help!!!! email [email protected]
