DVD Driver is not working on my laptop so cannot install the cd which came with my Technika VGA Webcam and therefore I cannot use the webcam. Is there anywhere I can download the software?
1. Start > Run. 2. regedit 3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder. 4. Select File > Export 5. save the file to the Desktop in case you need to restore it 6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box. 7. Do the same for the UpperFilters line 8. Close the Registry Editor. 9. Restart Windows.
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
Click Start
Collapse this imageExpand this image, type regedit in the Start Search box, and then click regedit in the Programs list.
Collapse this imageExpand this imageIf you are prompted for an administrator password or confirmation, type your password, or click Continue.
Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
In the right pane, right-click UpperFilters, and then click Delete.
Click Yes to confirm the removal of the UpperFilters registry entry.
In the right pane, right-click LowerFilters, and then click Delete.
Click Yes to confirm the removal of the LowerFilters registry entry.
Exit Registry Editor, and then restart the computer.
Now try to Install the driver from the cd if still not working then use this link to download the driver:www.filebuzz.com/.../Technika_Vga_Webcam_Driver/1.html
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A100-S8111TD
when i bought toshiba laptop 1 year ago, i would plug headphones in and sound would only come out...
(More)
when i bought toshiba laptop 1 year ago, i would plug headphones in and sound would only come out headphones. Now it comes out of the computer and headphones defeating the purpose! I need help!
It doesn t want to set up unless you hold esc and then press F2 then it sets up and powers down a...
(More)
It doesn t want to set up unless you hold esc and then press F2 then it sets up and powers down a couple minutes later
wana unlock toshiba tg 01 in india mobile dint got a product so added anythng need assitance for...
(More)
wana unlock toshiba tg 01 in india mobile dint got a product so added anythng need assitance for toshiba tg01 mobile handset
monitor wont work toshiba satelite laptop turn it on runs but it wont come on i cleaned the hinges...
(More)
monitor wont work toshiba satelite laptop turn it on runs but it wont come on i cleaned the hinges and the lock not sure what to do
