I have a Canon i350 color printer that is 6 years old. When the power is on the power lamp flashes a long green, then alternates between orange and green for a total of 7 orange flashes, then flashes a long green; then repeats the sequence.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
when i press the scanner button, it does not work, the power button starts flashing right after i...
(More)
when i press the scanner button, it does not work, the power button starts flashing right after i press "scan" other then that, the copier and printer work, can someone please help me?
i get no colour print from the PSC 1610 printer. Bought a new genuine colour cartridge and it worked...
(More)
i get no colour print from the PSC 1610 printer. Bought a new genuine colour cartridge and it worked for a few days and then just prints in black and white. Cartridge is still full has plenty of ink but not putting it on paper. No message to check or realign when the cartridge is put in. tried printing from both pc and printer with the same result
