Do not reset the router. If you reset the router you will loose all the other settings of the router. The WEP key is the password to connect to the wireless network. that is set up on the router. You will find the WEP key if you open the set up interface of the router. Click Here to know how to open the set up interface of the router
Unplug the router and then press and hold the reset button for 20 seconds. That should reset the router to the default settings. then connect to 192.168.0.1 user name will be admin. leave password blank. Good luck.
You can hook up a desktop to the router through the cable in Port 1 and access the router through the web browser. Once in the router configuration, you can reset the WEP password, or...
You can also reset the router back to default settings by taking a pen and holding in the little reset button on the back of the router. Hold it down for 10 seconds or until all the lights go out on the front and reconfigure the router.
Was this helpful?
Yes
No
Popular Solutions for D-Link AirPlus DI-524 Wireless
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the...
(More)
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the internet at the same time. It also drops when I get an incoming message on my blackberry.
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for...
(More)
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for my computer wireless card upstairs?
when i go through router setup it locks out my laptop. i need securitybut my own access at same...
(More)
when i go through router setup it locks out my laptop. i need securitybut my own access at same time.
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried...
(More)
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried to several time, but it just causes the router to lock up. I've tried reseting the unit again. And, yes I've cycled the power a few times ? no love. Y'all have any voodoo to solve this problem?
