Question about O2 Xda Orbit Smartphone
Screen keeps going blank - then only works when connected to mains adapter or usb
The screen just dies when I tap the screen. I can get it working again by plugging in mains adapter, but it dies again when disconnected and the screen is tapped. The battery is showing almost fully charged. I have tried a soft reset, but no use.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 143 Answers
I have the same problem, but sometimes when i connect the charger it does not charge or pcsync..
where the charge slot is on xda-orbit/htc-p3300, there is 2pins inside and if i slightly bend them to ensure a connection it works no problem.
however....
when i disconnect the phone from charge or pcsync, it keeps turning off.
any hints wat to do if hard reset dont work?
Posted on Jan 07, 2010
Hi try a hardreset hold both soft keys and then softreset
the softkeys i refer to are marked with - - between the call n disconnect buttons.
could solve ya problem....... yay
bear inmind that a hard reset means the phone with go to factory settings so back it up lol
Posted on Jan 08, 2008
How do i get my dell e6400 to go on to an external screen
Plug a monitor into the video connector. Right click on your desktop, select Screen Resolution, and then using the setup panel, identify your external monitor and finish the setup.
May 04, 2015 | Dell LATITUDE Computers & Internet
My Sony Bravia keeps shutting off unexpectedly. It does warn me with a statement on the screen that says" TV picture is about to go off" or something to that effect.
Wouldnt it be nice if it would say " Picture is about to go off because BLANK is bad and tell you what is was lol.. Anyway.. IF your set is an LCD tv then here are some symptoms and causes
Main pcb common failures picture and sound will at random just go off with a black screen. Green power light stays lite.
Power supply: depending on severity normally set will cut off and power light will go off or blink
Inverter board. Picture will go off but generally audio will continue to work
The panel (screen) itself could be going bad as well. Sometimes if its the panel you can tap (kinda hard) lets call it a love tap lol... across the top of the screen. If it starts working again then suspect the panel which costs more than a new tv..
There wasnt enough information in the complaint for me to rule some of these out for you. Hope it helps....
Oct 19, 2010 | Sony Televison & Video
Tom tom is dimming and blanking the screen within about 30 seconds. I can touch the screen and it reappears but does it again
Tap on: the main screen. Tap on: Change Preference. Tap on: Arrow Keep tapping on the arrow till you reach Preferences 6 of 6 Page. Here you will find Battery saving preference. Tap on it. Tap on: Never dim screen. (I think you selection would be dim screen between instructions at present.). Tap done. On the next screen select : Device stays on when external power is lost. (A green tick mark should appear to verify it is selected.) Tap done.
May 09, 2010 | GPS
Screen remains blank although at times the machine gives directions.
Tap on: the main screen. Tap on: Change Preference. Tap on: Arrow Keep tapping on the arrow till you reach Preferences 6 of 6 Page. Here you will find Battery saving preference. Tap on it. Tap on: Never dim screen. (I think your selection would be dim screen between instructions at present.). Tap done. On the next screen select : Device stays on when external power is lost. (A green tick mark should appear to verify it is selected.) Tap done.
May 10, 2010 | Tomtom GO 930 GPS Receiver
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Blank square on screen after installing a Linksys USB adapter
This is a problem with the wireless adapter to correct this problem you uninstall and download the latest software from linksys site and install that one to your computer...
Sep 26, 2009 | Linksys Rangeplus Wireless Pc Adapter
Dell Inspiron 1501
If the laptop keeps working, and you can use it on an external screen, then it is likely an hardware fault.
First perform a complete system recovery, like probably already instructed by the Dell support helpdesk. This will practically exclude the possibility of a driver or system problem.
If the problem is hardware , then you may have a faulty inverter board , a bad LCD display/LCD ribbon connection, or a faulty video adapter (integrated with motherboard).
If the problem is the inverter, then the screen will go dark, and the laptop will keep working on external display. This is probably your case.
If the problem is LCD display or ribbon cable, then the display will be blank with light on , and the laptop will keep working on external monitor.
Fault concerning video adapter usually cause the the system not to work at all, and it is uncommon under conditions described.
Sep 04, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Cant get internet to work on my cect p168c i have tmobile
you have to follow this step by step. if youve tried this and it dont work i have no clue, i have set this up for several people on this site with no problems. as for the comment on uk if you will post this in a seperate help i wil try and help. it is limited to amount of text i can add. i have t mobile and these settings work for me. since you only said internet that is all i am posting.
Data Account Services:
1.) Setting up regular data account services for MMS & T-Zones access.
2.) From the main screen tap the Service icon.
3.) Tap Data account on the Services menu.
4.) Tap GPRS on the Data account menu.
5.) Choose any of the profiles in the current list and tap the button.
6.) You are now on the Edit screen.
7.) Tap the area just below Account name, then tap Edit at the bottom of the screen.
8.) Tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
9.) Tap the area just below APN, then tap the Edit button
10.) Tap in the following text between the quotes
“wap.voicestream.com”
11.) Both the User name & Password areas should remain
BLANK. If they are not blank, then tap on each one
and Clear what is in them so they are both blank.
12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
arrows to move the selection so it has Secure, then tap Done.
13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of
the screen. You should now be on the Services menu.
15.) Tap WAP on the Services menu.
16.) Tap Settings on the Internet services menu.
17.) Tap Edit profile on the Settings menu.
18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up
at this time for MMS messaging.
19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
20.) Tap on Profile 8. Tap Edit profile.
21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
22.) Clear the current text, then tap in the following text between the quotes
“T-Zones”
23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen.
24.) Clear the current text except for “HTTP://”, then tap in the following text between the
quotes after the HTTP://
“wap.myvoicestream.com”
25.) Tap the area below Data account, then tap Select at the bottom
of the screen.
26.) Tap GPRS on the Data account menu.
27.) Scroll down the list until you come to T-Mo MMS, the data
account set up earlier under the Data Account Services
section. Tap on T-Mo MMS to select it.
28.) Tap the area below Connection type, then tap Select at the
29.) Tap on HTTP, then tap on OK at the bottom of the screen.
30.) Tap the area below Proxy address, use the numeric keyboard at
the bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050
under Proxy address.
31.) Tap the area below Proxy port, use the numeric keyboard again
to tap in the following numbers “8080” to replace the current 0
value.
32.) Tap the OK button on the bottom of the screen.
33.) The areas under both User name & Password should remain
BLANK. If they are not blank, select each, and Edit them by
clearing all text.
34.) Next tap the Done button at the bottom of the screen.
35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
back to the Select profile screen where a big green check mark will be beside the newly
saved T-Zones profile.
37.) Tap the On/Off button once to exit to the main screen.
38.) If you ONLY want MMS and T-Zones access without the full internet connection,
you can now skip down to the MMS Messaging section and continue setting up MMS
messaging; otherwise continue below at step 39 to set up a second data account service
which will be used for your internet connection.
39.) Setting up a 2nd data account service for full internet access.
40.) Tap the Service icon on the main menu.
41.) Tap Data account on the Services menu.
42.) Tap GPRS on the Data account menu.
43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the
button. The profile right under it would be fine.
44.) You are now on the Edit screen.
45.) Tap the area just below Account name, then tap Edit at the
46.) Tap in the following text between the quotes
“T-Mo Internet”
47.) Tap the area just below APN, then tap the Edit button at the
48.) Tap in the following text between the quotes
“epc.tmobile.com”
49.) Both the User name & Password areas should remain
BLANK. If they are not blank, then tap on each one and Clear
50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
52.) Now that you have set up a second account service for internet use we can adjust the
WAP settings for T-Zone to use this faster and less restricted internet gateway.
53.) Tap the On/Off button once to return to the main menu.
54.) Tap the Service icon on the main menu.
55.) Tap WAP on the Services menu.
56.) Tap Settings on the Internet services menu.
57.) Tap Edit profile on the Settings menu.
58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up
at this time for SMS messaging.
59.) Tap T-Zones on the Select profile menu.
60.) Tap Edit profile on the T-Zones menu.
61.) Tap the area below Data account on the Edit profile menu,
then tap the Select button at the bottom of the screen.
62.) Tap GPRS on the Data account menu.
63.) Find and tap on T-Mo Internet on the Data account menu.
64.) Tap the Done button on the bottom of the Edit profile menu.
65.) A Save? question box should pop up. Tap the Yes button at
66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
67.) Tap the On/Off button once to exit to the main screen.
Internet Access:
If all you want to use for internet surfing is the phone’s built-in browser, and you have set up
the data account service for the internet in the earlier setup, then you are ready to surf the
internet by simply tapping on Service from the main menu. Then tapping on WAP and using
the various options to navigate the internet like Homepage, Input address, etc. However, this
won’t provide as robust an internet experience as a Java based internet program such as Opera
Mini 3.1 or 4.1, or another java based internet browser. If you do decide to install a Java
program for browsing the internet, there is one more setting which must be changed prior to
using the Java internet browser.
Java Internet Settings:
1.) From the main menu tap on the Java icon.
2.) Tap Java settings from the Java menu.
3.) Scroll down and tap the area just below Java SIM1 (SIM2) profile,
which ever SIM you are currently setting up.
4.) Use the arrows to scroll the setting until T-Zones appears in the
box.
5.) Tap the OK button at the bottom of the screen.
Now you should be completely set up for internet on the T-Mobile network if you have a T-Mobile internet
plan!
May 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Update
im sorry but you might have to be a bit more specific. I dont think u can update a ds game. and u cant connect it to the computer. the possible putcome i gathered from that is that he wants to play his game online and trade pokemon etc. meaning u need to connect the ds to your computer wirelessly using a
-nintendo wi-fi usb connector-( a usb drive u basically plug into ur computer and gives off internet for nintendo products) or a -wireless router or modem- ( the black box that the cables go through for internet).
When your grandson plays the game and wants to go online, (i will explain how to use this using directions in the game)
1. turn on the ds and load the game
2. watch the introduction movie (shiny pokemon)
3. on the main screen where you decide to either continue, new game, or -NINTENDO WFC SETTINGS-, go to nintendo wfc settings
4.tap the blue box labelled nintendo wi-fi connection settings
5.if ur using a Wi-fi usb tap connect to wifi usb or if using wireless internet tap a blank connection square
6. follow the prompts for the wifi usb and u will be connected to the internet
7. for wireless internet, tap search for an access point
8. when it has found the wireless internet tap O.K/connect/next etc and follow the prompts
9.when thats connected return to pokemon Diamond main screen then tap new game/continue to play
10. walk to the pokemon centre and go downstairs to battle online - or go into a house in
(Jublife city?) to trade pokemon online
WOAH!! that was a lot of writing!
hope i helped plz make a comment or something if u need my help again
Sep 13, 2008 | Nintendo DS Console
O2 Xda Orbit Smartphone Logo
219 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
