GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Ge ice maker wont make ice , no water entering
By ladeira on Oct 25, 2009
ge ice maker wont make ice , no water entering tray clynoid water valve ok.
Same Problem
Nov 25, 2009
-   I have a samsung side by side fridge freezer water is being dispenced ok on the water button but no water is coming into the ice tray. the mechanism for ejecting the ice is working fine-   vicber1966
Solution #1
posted on Oct 25, 2009
Somewhat Helpful)
coreybendett
Rank: Guru
Rating: 91%, 33 votes
Take the front cover off of the ice maker.  Under the cover there are some test points,  V stands for valve and should have 120,  L stands for line and should have 120,  N is nuetral and should have continuity to ground. If all of these check good replace the ice maker, If not troubleshoot the wiring.  The fastest way to find out if it is the ice maker it to jumpre the two middle terminals on the ice maker plug.  If it spits out water replace the ice maker.
Comments:
Oct 25, 2009
- Take the front cover off of the ice maker.  Under the cover there are some test points,  V stands for valve and should have 120,  L stands for line and should have 120,  N is nuetral and should have continuity to ground. If all of these check good replace the ice maker, If not troubleshoot the wiring.  The fastest way to find out if it is the ice maker it to jumpre the two middle terminals on the ice maker plug.  If it spits out water replace the ice maker.
Oct 25, 2009
Was this helpful?
Yes
No
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
Need to remove the doors on my GE TFX27PF side by side refrigerator to move it to the basement... (More)
Answer
My GE Profile Arctica leaks periodically...enough to cause damage behind the unit. Stops when I call... (More)
Answer
Freezer is cold but ice is melting and refreezing after it runs lower in the freezer
Answer
no water to ice maker. I think water shute is frozen, because I can get water to the door. I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile 26.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
